DTM Series
DTM Series
Manufacturer: Duotec
Forum Discussion
Number of units
7064
Online
12431
Total
Features DTM Series:
  • Blackbox
  • Dual SIM
  • GLONASS support
Supported in Wialon:
  • Accelerometer
  • ADC sensors
  • ECO driving
  • Remote management via GPRS
  • Digital sensors
  • Remote management via SMS
  • Tachograph file download
  • Communication via TCP
The following data should also be added to DTM Series unit properties section of Wialon GPS tracking software :
Device type: DTM Series
Unique ID: imei
Specify the following parameters in configuration software or configuration DTM Series for use in Wialon Hosting :
Server port: 20897
12431 units of DTM Series device type are connected to Wialon Data Center. This represents 0.51% of all AVL Hardware connected.
hdop Horizontal Dilution of Precision
v Valid of coordinates
cur_time Current time
sensor_code Sensor code
dinX Digital inputs, X - number of sensor
doutX Digital outputs, X - number of sensor
dev_code Device code
accum_voltage Voltage on internal battery v
board_voltage Vehicle voltage v
omnicom Sensors LLS: Omnicom
can_X_code CAN code
battery_voltage Battery voltage v
gsm_signal GSM Signal Strength Levels
err_code Error codes devices
param_X Device code
sw_version_lite Firmware version lite
device_mode MODE of device
sw_version Firmware version
meter32_X Sensor code
pwr_ext Voltage of external power supply v
pwr_int Power supply internal battery v
sats_gp Number of GPS satellites
sats_gl Number of GLONASS satellites
ext_pwr_on Presence of an external power supply
int_pwr_state Charge the backup battery.
gsm_st Status of the GSM modem
gps_st Status of the GPS/Glonass module
mw Motion sensor
sim_type SIM card / SIM chip (1 - SIM chip, 0 - SIM-card)
sim_in Presence of SIM-card/SIM chip
gps_ant Sstatus of the GPS/Glonass antenna
stat_X Status, X - number of status
vdop Vertical Dilution of Precision
pdop Position Dilution of Precision
mcc Mobile country code
mnc Mobile network code
lac Location area code
cid Cell tower ID
gsm GSM Signal Strength Levels
nav_st Status of the GPS/Glonass module
imps_X Number of pulses on X, X - number of inputs
freq_X Frequency on X, X - number of inputs
temp_1wire_X Temperature sensor 1 wire, X - number of sensor
can_sequrity_state CAN – security state flags
can_log_number Program CAN LOG
can_eng_full_time CAN - the complete operating time of the engine
can_full_mileage CAN - full mileage
can_full_fuel_cons CAN - full fuel consumption
can_fuel_level CAN - fuel level in the tank %
can_fuel_litres CAN - fuel level in the tank l
can_rpm CAN - speed engine speed
can_eng_temp CAN - engine temperature
can_speed CAN - speed
can_axle_loadX CAN - pressure on the axis, X - number of axis
can_accident CAN - controllers accident
lls_X_level Value of the level FLS, Protocol LLS
lls_X_temp Value of the temperature FLS, Protocol LLS
ml_ret MicroLink - Return Temp
ml_sup MicroLink - Supply Temp
ml_sp MicroLink - Setpoint Temp
microlink_sn_sw MicroLink - serial number comp + SW Rev
driver_status Driver status
driver_status_id Driver status ID
gank_X Substance
info_messages Informational messages
hs Hardware status
iccid_X ICCID sim card, X - number of card
unit_id ID device
wln_accel_max Maximum acceleration value g
wln_brk_max Maximum deceleration value g
wln_crn_max Maximum angular acceleration g
st0
Mode service / sensor opening:
0 - monitoring
1 - protection
st1 SOS mode monitor / alarm mode protection / 1-wire discrete mode
st2
Status of plugs:
0 - ignition on of the CAN virtual
1 - ignition off of the CAN virtual
User manual and detailed device description is available here.
Contact Wialon and achieve the most ambitious goals with telematics
Fill out a request form to get started with Wialon
Step 1
Step 2
Step 3
First name*
Last name*
Company*
Email*
Phone
