BSJ Video
BSJ Video
Manufacturer: BSJ Technology
Number of units
625
Online
1536
Total
Features BSJ Video:
  • 4G/LTE
  • Blackbox
Supported in Wialon:
  • Event video
  • Live stream
  • Manual video saving
  • Playback
The following data should also be added to BSJ Video unit properties section of Wialon GPS tracking software :
Device type: BSJ Video
Unique ID: custom
Specify the following parameters in configuration software or configuration BSJ Video for use in Wialon Hosting :
Server port: 22694
1536 units of BSJ Video device type are connected to Wialon Data Center. This represents 2.45% of all Video monitoring connected.
hum Range 0–100%RH (unit: 1%RH). 0xFF = Humidity detection not supported
end_time End time of MDVR upload number of passengers packet
esc_level Escort TD fuel sensor level
mielta_level Mielta fuel sensor level
mielta_manufacturer_data Mielta sensor internal transparent data
alm_thre1
Warning threshold 1
start_time Start time of MDVR upload number of passengers packet
air_quality2 Air quality sensor level
temp1 Temperature sensor level
alarm_status
Alarm status, bits(1-32)
bit1: cameraabnormal
bit2: Main memory exception
bit5: abnormal speaker
bit6: Abnormal battery
bit7~bit10:reserved
bit13~bit32:reserved
route_alarm
Route alarm
tkstar_base_st_towe_num TKstar TK905 4G base station tower number
mielta_fuel_tank_heigh Mielta fuel tank height sensor value
humidity2 Humidity sensor
speed_drvng_rec
Speed driving rec
reply_serial_num Reply message serial number
esc_level_# Escort TD fuel level sensor
section_id
Section ID
veh_signal_status
Veh. signal status
driving_results
Driving results
sign_stat
Sign status.
  • 0x00: Not available
  • 0x01: Start sign
  • 0x02: End sign
road_sign_d
veh_ah_dst
param_id_#
Parameter value
tkstar_light_alarm
0 see light
1 see no light
ibutton IButton ID
alm_lvl
Warning level:
  • 0x01: Level 1 warning
  • 0x02: Level 2 warning
memory_fault_alarm
workstate
Workstate,
0x01: normal work
0x02: standby mode
0x03: Upgrade maintenance
0x04: Device is abnormal
0x10: Disconnect
direction
Direction
dev_type
Deviation type:
  1. 0x01: Left deviation
  2. 0x02: Right deviation
road_sign_t
Road sign type
  • 0x01: Speed limit sign
  • 0x02: Height limit sign
  • 0x03: Weight limit sign
device_humidity
device humidity
accel_y Acceleration value Y axis
voltage Internal voltage level
video_signal_loss_alarm
fuel_volume
Fuel volume
hdop Horizontal Dilution of Precision
pwr_int
Internal power
veh_stat
alm_thre2
Warning threshold 2
alm_time
Alarm time threshold
temp_hum_stat
BIT[0–3]: Temperature Status (0 = Normal, 1 = High alarm, 2 = Low alarm)
BIT[4–7]: Humidity Status (0 = Normal, 1 = High, 2 = Low) Example: 0x21 = High temp + Low humidity alarm
device_temp
device temperature
alm_id
alarm_flag
Alarm flag (Bits1-32):
Bit2: 1: Over speed alarm
Bit4: 1: Risk warning
Bit12: 1: Camera malfunction
Bit14: 1: Over speed warning
Bit16-Bit18: Reserve
Bit20: 1: Timeout parking
Bit24: 1: Off track alarm
Bit30: 1: Collision warning
Bit31: 1: Rollover warning
position_type
Position type
iccid
SIM Card ICCID Number
mielta_temperature Mielta transparent temperature sensor value
alm_type
Alarm/event type
Values meaning if info_id = 0x64:
1 - Forward collision warning
2 - Lane departure warning
3 - Vehicle distance too close alarm
4 - Pedestrian collision alarm
5 - Frequent lane change warning
6 - Road sign overrun alarm
7 - Obstacle alarm
8 ~ 15 - User-defined
16 - Road sign recognition event
17 - Active capture event
18 ~ 31 - User-defined
Values meaning if info_id = 0x65:
1 - Fatigue driving alarm
2 - Phone call alarm
3 - Smoking alarm
4 - Distracted Driving Alarm
5 - Driver abnormal alarm
6 - Probe blocking alarm
7 - User-defined
8 - User-defined
9 - User-defined
10 - Not wearing seat belt alarm
11 - Infrared blocking sunglasses failure alarm
12 - Both hands off the steering wheel at the same time
13 - Playing with mobile phone alarm
16 - Automatic capture event
17 - Driver change event
state_flag
Status (Bits 1-32):
Bit1: 0: ACC off; 1: ACC on
Bit7-Bit8: Reserve
Bit23-32: Reserve
accel_x Acceleration value X axis
veh_ah_spd
oil_data_# Oil sensor data
event_#
Event
cur_adj_oil_lvl_# Jiutong Oil Rod Extension Protocol, the oil level value after applying necessary adjustments or corrections.
abnormal_driving_alarm
Bit1:fatigue;
Bit2:call;
Bit3:smoking;
user_msg
User mesage
device_status Device statue
tilt_y Y-axis tilt angle, unsigned number, unit: 0.1 degrees
video_alarm
Video related alarm
Bit 1 Video signal loss alarm
Bit 5 Over passengers alarm
Bit 8-32 Reserved
driving_time
Driving time
temp
Short int type, valid range -40~125°C (unit: 0.1°C).
0xFFFF = Temperature detection not supported
cur_oil_lvl_# Current oil level
cur_liq_lvl_# Current liquid level
pwr_ext
External voltage
driving_time_alarm
Driving time alarm
people_get_off Number of get off passengers
video_signal_block_alarm
overspeed_alarm
Overspeed alarm
driver_id
driver ID
tilt_x X-axis tilt angle, unsigned number, unit: 0.1 degrees
chrg_volt Represents charging voltage
esc_freq Represents the sensor's measured frequency, which is proportional to the fuel level in the tank.
alarm_event_id
Alarm event ID
air_quality3 Air quality level
battery_lvl Battery level
odometer
Odometer
info_id
Additional information ID
  4. 0x14 - Video-related alarm
  7. 0x17 - Memory fault alarm
accel_z Acceleration value Z axis
ED08R - 8CH AI MDVR - Integrates 4G communication, GNSS positioning, ADAS, DMS,BSD, supports 8-channel audio and video recording, SD card and hard disk storage, driving data recording, two-way calls, real-time monitoring and other functions.
EH03T - 4G Smart Video Terminal - cost-effective vehicle monitoring terminal. Built-in GPS/Beidou positioning module, 4G module and WIFI module, audio and video codec SOC, support 4 channel video and 2 channel audio and two TF card, video storage function.
ED08R - 4CH AI MDVR - supports audio and video recording, SD card storage, driving data recording, platform upload, TTS voice broadcast, real-time monitoring, ADAS, DMS, BSD AI algorithm,and other functions.
Supported models:
  • EH03T
  • EH15
  • ED02R
  • ED08R
  • EH13-P
  • EH11
  • EH13
  • EH16
  • EH17
  • EH18
  • EH19
  • EH20
  • DR01
  • D8
  • E8
Grow your business with us
