Surfsight AI-12 APIv2.0
Manufacturer: Lytx
Number of units
Online
191
Total
Supported in Wialon:
  • Event video
  • Live stream
  • Manual video saving
  • Playback
The following data should also be added to Surfsight AI-12 APIv2.0 unit properties section of Wialon GPS tracking software :
Device type: Surfsight AI-12 APIv2.0
Unique ID: imei
Specify the following parameters in configuration software or configuration Surfsight AI-12 APIv2.0 for use in Wialon Hosting :
Server port: 22075
191 units of Surfsight AI-12 APIv2.0 device type are connected to Wialon Data Center. This represents 0.31% of all Video monitoring connected.
event_id Id of event
wl_event_type
cam_N_file_id Id of a file from the camera, N- Id of the camera
cam_N_type Type of the camera, N- Id of the camera
cmd_res Result of command
video_uri Link to the video file
event_type Type of event
In order to change the address and port from APIv1 to APIv2.0 and vise versa, you need to send the "Enable webhook" command and in the "Address for webhook" tab indicate proper IP and port.
Grow your business with us
