Navtelecom Signal S-2550
Manufacturer: Navtelecom
Forum Discussion
Number of units
60
Online
252
Total
The following data should also be added to Navtelecom Signal S-2550 unit properties section of Wialon GPS tracking software :
Device type: Navtelecom Signal S-2550
Unique ID: imei
Specify the following parameters in configuration software or configuration Navtelecom Signal S-2550 for use in Wialon Hosting :
Server port: 20871
252 units of Navtelecom Signal S-2550 device type are connected to Wialon Data Center. This represents 0.01% of all AVL Hardware connected.
accel_pedal_pos Accelerator pedal position %
brake_pedal_pos Position of the brake pedal %
can_axis_weight Axle load kg
can_dfl_level Liquid level in the diesel exhaust filter %
can_dfl_volume Liquid level in the diesel exhaust filter liter
can_dtm Distance before maintenance km
can_engine_hours Total time of engine operation sec
can_fuel_consumpt Full fuel consumption liter
can_fuel_level Level of fuel in the tank %
can_fuel_volume Level of fuel in the tank liter
can_mileage Full vehicle mileage km
can_speed Speed of vehicle km/hour
dig_temp Temperature from a digital sensors °C
engine_coolant_temp Temperature of the engine coolant °C
engine_hours Engine hours from sensor of the generator sec
engine_load Load on the engine %
engine_rpm Engine speed r/min
event_code Event code
freq Frequency from analog-to-frequency sensor hz
gsm GSM level dB/m
imp_counter Voltage from analog input V
inter_mileage Mileage between two points of the track km
lang Firmware version
last_key Key
mileage Current mileage km
mileage_time Total number of seconds on the last stage of the journey
modules_st2 The status of functional modules 2 (bit field)
modules_st The status of functional modules 1 (bit field)
msg_type Type of message
navigation_system Navigation system
nav_rcvr_state The state of the navigation sensor (0 - Off, 1 - On)
positions_count The total number of points calculation navigation receiver coordinates with a rate of once per second
pwr_ext External voltage V
pwr_int Internal voltage V
rs232fuel_level Fuel level from rs232
rs232fuel_temp Fuel temperature from rs232 °C
rs485fuel_level Fuel level from rs485
rs485fuel_temp Fuel temperature from rs485
software_released Date of last change of firmware
software_version Software version
status Device status (bit field)
temp Temperature from a digital sensor °C
valid_nav 0 - navigation is invalid, 1 - navigation is valid
val_positions_count The number of points of calculation by the navigation receiver coordinates with a rate of once per second when a valid navigation data.
sats_gl Count of Glonass satellites
sats_gps
Count of GPS satellites
sats_gal
Count of Galileo satellites
sats_comp
Count of Compass satellites
sats_beid
Count of Beidou satellites
sats_dor
Count of DORIS satellites
sats_irnss
Count of IRNSS satellites
sats_qzss
Count of QZSS satellites
hdop Horizontal Dilution of Precision
pdop Position Dilution of Precision
prec_info Additional high-precision navigation status
cell_id Cell tower ID
lac Location area code
mcc Mobile country code
mnc Mobile network code
rx_level Received Signal Strength Indicator
lbs_time Last time received LBS
tpms_pressure_X Pressure in the X wheel
tpms_temp_X Temperature in the X wheel
tacho_active_driver1 First driver's activity
tacho_slot1 First driver's card slot status
tacho_active_driver2 Second driver's activity
tacho_slot2 Second driver's card slot status
tacho_mode Mode of operation of the tachograph
tacho_state Status flags from tachograph
tacho_speed Speed from tachograph
tacho_odom Odometer from tachograph
tacho_time Time from tachograph
dm_status Current state of the driver taken from the display module
dm_mess_n Index of last received message
time_shift Increment of time relative to the previous entry 1/100 s
acc_x Linear acceleration along the X-axis
acc_y Linear acceleration along the Y-axis
acc_z Linear acceleration along the Z-axis
mid_acc Module of the acceleration vector
wln_accel_max Maximum value of the positive acceleration for the period
wln_brk_max Maximum value of the negative acceleration for the period
wln_crn_max Maximum value of the angular acceleration for the period
p_count Counter data of passenger traffic
autoinf_status Status of the answering machine
last_geo_id ID of the last geofence
last_stop_id ID of the last stop
cur_route_id ID of the current route
camera_status​ Status of camera
Contact Wialon and achieve the most ambitious goals with telematics
Fill out a request form to get started with Wialon
Step 1
Step 2
Step 3
First name*
Last name*
Company*
Email*
Phone
