Aisafer W2S
Aisafer W2S
Manufacturer: Aidriving
Discontinued
Number of units
0
Online
0
Total
Features Aisafer W2S:
  • 4G/LTE
  • Blackbox
  • GLONASS support
Supported in Wialon:
  • Event video
  • Live stream
  • Manual video saving
  • Playback
  • Alarm button
  • Communication via TCP
The following data should also be added to Aisafer W2S unit properties section of Wialon GPS tracking software :
Device type: Aisafer W2S
Unique ID: custom
Specify the following parameters in configuration software or configuration Aisafer W2S for use in Wialon Hosting :
Server port: 22669
0 units of Aisafer W2S device type are connected to Wialon Data Center. This represents 0% of all Video monitoring connected.
param_id_#
Parameter value
event_#
Event
alarm_flag
Alarm flag (Bits1-32):
Bit2: 1: Over speed alarm
Bit4: 1: Risk warning
Bit12: 1: Camera malfunction
Bit14: 1: Over speed warning
Bit16-Bit18: Reserve
Bit20: 1: Timeout parking
Bit24: 1: Off track alarm
Bit30: 1: Collision warning
Bit31: 1: Rollover warning
state_flag
Status (Bits 1-32):
Bit1: 0: ACC off; 1: ACC on
Bit7-Bit8: Reserve
Bit23-32: Reserve
odometer
Odometer
fuel_volume
Fuel volume
speed_drvng_rec
Speed driving rec
alarm_event_id
Alarm event ID
overspeed_alarm
Overspeed alarm
position_type
Position type
section_id
Section ID
route_alarm
Route alarm
direction
Direction
driving_time_alarm
Driving time alarm
driving_time
Driving time
driving_results
Driving results
video_alarm
Video related alarm
Bit 1 Video signal loss alarm
Bit 5 Over passengers alarm
Bit 8-32 Reserved
video_signal_loss_alarm
video_signal_block_alarm
memory_fault_alarm
abnormal_driving_alarm
Bit1:fatigue;
Bit2:call;
Bit3:smoking;
veh_signal_status
Veh. signal status
user_msg
User mesage
veh_stat
info_id
Additional information ID
  4. 0x14 - Video-related alarm
  7. 0x17 - Memory fault alarm
alm_time
Alarm time threshold
sec
alm_thre1
Warning threshold 1
alm_thre2
Warning threshold 2
workstate
Workstate,
0x01: normal work
0x02: standby mode
0x03: Upgrade maintenance
0x04: Device is abnormal
0x10: Disconnect
alarm_status
Alarm status, bits(1-32)
bit1: cameraabnormal
bit2: Main memory exception
bit5: abnormal speaker
bit6: Abnormal battery
bit7~bit10:reserved
bit13~bit32:reserved
alm_lvl
Warning level:
  • 0x01: Level 1 warning
  • 0x02: Level 2 warning
alm_id
sign_stat
Sign status.
  • 0x00: Not available
  • 0x01: Start sign
  • 0x02: End sign
veh_ah_spd
km/h
veh_ah_dst
dev_type
Deviation type:
  1. 0x01: Left deviation
  2. 0x02: Right deviation
road_sign_t
Road sign type
  • 0x01: Speed limit sign
  • 0x02: Height limit sign
  • 0x03: Weight limit sign
road_sign_d
TKStar
tkstar_base_st_area_code - Area code
tkstar_base_st_contry_code - Country code
tkstar_base_st_oper_num - Operator number
tkstar_base_st_towe_num - Tower number
tkstar_bat_charge - Battery charge percentage
tkstar_displacement_alarm - Extended alarm status
tkstar_iccid - SIM card ICCID number
tkstar_motion_status - (00)Still to motion; (01)Move to rest;
tkstar_pos_status - (00) Not positioned; (10) WiFi positioning; (01) GPS
positioning;
tkstar_term_built_in_volt - the internal voltage value
tkstar_vibration_alarm
Grow your business with us
