CMSV6 Gateway
CMSV6 Gateway
Manufacturer: Babelstar
Number of units
Online
86
Total
Supported in Wialon:
  • Event video
  • Live stream
  • Manual video saving
  • Playback
The following data should also be added to CMSV6 Gateway unit properties section of Wialon GPS tracking software :
Device type: CMSV6 Gateway
Unique ID: custom
86 units of CMSV6 Gateway device type are connected to Wialon Data Center. This represents 0.14% of all Video monitoring connected.
adas1
Active safety adas alarm status bit Lv1
Bit0: forward collision alarm, bit1: lane departure alarm, bit2: vehicle distance over alarm, bit3: pedestrian collision alarm
bit4: frequent lane change alarm, bit5: road sign over limit alarm, bit6: obstacle alarm, Bit7: Curved speed warning
(Valid when lg=2)
adas2
Active safety adas alarm status bit Lv2
(Valid when lg=2)
bsd1
Active safety bsd alarm status bit bit0: left blind zone alarm, bit1: right blind zone alarm, bit2: rear approaching alarm
(Valid when lg=2)
driver_id Driver id
driver_name Driver Name
driver_number Driver's Work Number
dsm1
Active safety dsm alarm status bit Lv1
Bit0: fatigue driving alarm, bit1: call alarm, bit2: smoking alarm 3: long time no visual alarm, bit4: system can not work normally alarm
bit5: driver does not wear seat belt alarm, bit6: driving The member is not in the driver's seat alarm, bit7: the driver's hands are off the steering wheel alarm, bit8: distracted driving alarm (Su), bit9: driver abnormal alarm (Su)
(Valid when lg=2)
dsm2
Active safety dsm alarm status bit Lv2
(Valid when lg=2)
cmsserver
fuel
Fuel
Unit: L, you must first use divided by 100
mileage
mileage
Unit: m.
m
status_1 Check "Device Status Description" for full status list
status_2 Check "Device Status Description" for full status list
status_3 Check "Device Status Description" for full status list
status_4 Check "Device Status Description" for full status list
temp_1 Temp Sensor 1
temp_2 Temp Sensor 2
temp_3 Temp Sensor 3
temp_4 Temp Sensor 4
protocol_type
Protocol Type
(Device Status)
network_type
1 - 3G
2 - WIFI.
online_status 0 - device offline
1- device online
(Device Status)
audio_type Audio Type
factory_subtype Factory Subtype
hard_type
1 - SD card
2 - hard disk
3 - SSD card
parking_time
Parking Time
Unit: sec.
sec
dwn_begin_time
dwn_end_time
dwn_path
dwn_status
dwn_type
file
file_begin_time
file_end_time
file_length
gateway_server_number
savename
video_type
video_uri
lab
text that labels video download task and could show the reason why video was requested
(Video File Info)
loc
File Location:
1 - device
2 - cmsv6 storage server
4 - cmsv6 download server
(Video File Info)
cha_n Video channel
(Video File Info)
arm
Alarm Info
Effective when the alarm recording.
(Video File Info)
arm1
1078 device return
Alarm identification 1, binary corresponding decimal integer, binary digit alarm
1 emergency alarm 2 overspeed alarm 3 fatigue driving 4 early warning 5GNSS module malfunction
The 6GNSS module is not connected to or is cut off by the 7GNSS antenna short circuit 8 terminal main power supply under voltage
9 terminal main power supply power off 10 terminal LCD or display failure 11TTS module fault
12 camera failure 19, driving overtime on the same day, 20 overtime parking 21 in and out of the area
22 out of route 23 of route of import and export line / over 24 route deviation from alarm 25 vehicle VSS fault
26 vehicles oil volume abnormal 27 vehicles stolen 28 vehicles illegal ignition 29 vehicles illegal displacement 30 collision rollover alarm
(Video File Info)
arm2
1078 device return
Alarm identification 2, binary corresponding decimal integer, binary digit alarm,
1 video signal loss alarm, 2 video signal occlusion alarm, 3 memory unit failure alarm
.4 other video equipment fault alarm 5 bus overcrowding alarm 6 alarm
abnormal driving behavior7 special alarm video to store threshold alarm
(Video File Info)
result
Result of a command issued to CMSV6 Gateway:
0 Successfully executed
1 Username does not exist
2 wrong password
3 The user has disabled
4 The user has expired
5 Session does not exist
6 System exception
7 Request parameter is incorrect
8 No authority to operate the vehicle or device
9 Start time is not greater than the end time
10 The time Longer than the range
11 Video download tasks already exist
12 Account already exists
13 No operating authority
14 The amount of device was limited(The amount of device reaches maximum).
15 The device is already exsist.
16 The vehicle is already exsist.
17 The device has been used.
18 Vehicle does not exist
19 Device does not exist
20 Equipment is not current company
21 The number of device registration does not match, please check the number of equipment exceeds the number of registration!
24 Network connection exception
25 The name of the rule already exists
26 Rules do not exist
27 Information does not exist
28 userSession already exists
29 Company does not exist
32 Equipment is not online
34 Single sign-on user, already logged in
alarm_type
Alarm Type
(Param Name "type")
alarm_param_#
Alarm Param #
(Param Name "p#")
Grow your business with us
