Wialon helps to control ice cream transportation in Sri Lanka
Tmp3suemsjf
Challenge
Ice cream manufacturers faced a problem of perishable product transportation in Sri Lanka. The temperature inside the containers reached almost 35°С above zero because of the tropical climate of the island. At the same time, drivers used to switch off refrigerators in order to save some fuel. As a result, the ice cream melted and became bad. Both shippers and receivers of ice cream suffered considerable losses.
Solution
Kloudip, a telematics service provider from Sri Lanka, has successfully solved it having implemented Wialon tracking system in the workflow of a big ice cream manufacturer. The following components were used for achieving the best result:
Wialon + Queclink + Sensolator
  • GPS trackers send and receive telematics data, monitor speed and the location of objects. Since the client's routes are quite lengthy (about 250 km), they installed hardware with long-life batteries in all the units. It helped to prevent communication failures and data losses on complicated road sections.
  • Queclink temperature sensors controlled the temperature inside the containers.
  • Sensolator is used for visual control of the temperature data received from the containers. If the temperature rises, the operator instantly receives a notification from the application.
Results
Wialon controls more than 50 of reefer containers. It helped the client of Kloudip to save money and increase revenue. The following results were achieved:
60%
The ice cream manufacturer came up with 60% savings compared to the previous year not having to take in the returned melted ice cream
35%
The company saved over 35% on their labor and cargo transportation costs while their staff didn’t have to take in the melted ice cream and ship substitutes of the goods
Similar case studies
