Hero-ME41-04
Hero-ME41-04
Manufacturer: Howen Technologies
Number of units
1589
Online
4936
Total
Features Hero-ME41-04:
  • 3G
  • Blackbox
Supported in Wialon:
  • ADC sensors
  • Camera connection
  • Event video
  • Remote management via GPRS
  • Digital sensors(RS232/RS485)
  • Live stream
  • Manual video saving
  • Playback
  • Communication via TCP
The following data should also be added to Hero-ME41-04 unit properties section of Wialon GPS tracking software :
Device type: Hero-ME41-04
Unique ID: custom
Specify the following parameters in configuration software or configuration Hero-ME41-04 for use in Wialon Hosting :
Server port: 21426
4936 units of Hero-ME41-04 device type are connected to Wialon Data Center. This represents 7.93% of all Video monitoring connected.
video_uri video URI
video_type video type: video/mp4
text information message
at Access network. 1-Ethernet 2-WIFI 3-2G
mt Media Type. 1-live view 2-playback 3-audio 4-file transmission 5-serial transmission
ch Media channel. starting from 1, 0 means no need for the channel.
mb mobile phone number
dt Device Type
ver Current version of device
ap The hotspot when MDVR connects to the sever in WiFi mode.
fuel_cons Fuel consumption
balance_fuel Balance fuel
mobile_net Mobile network. 0--unknown 1--normal 2--abnormal 3—not exist
gps_module GPS location module. 0--unknown 1--normal 2--abnormal 3—not exist
wifi_module WIFI module. 0--unknown 1--normal 2--abnormal 3—not exist
gsensor_status GSensor status. 0--unknown 1--normal 2--abnormal 3—not exist
recording_status
Bit0 - channel 1 is recording
Bit1 - channel 2 is recording
Bit2 - channel 3 is recording
Bit3 - channel 4 is recording
Bit4 - channel 5 is recording
etc.
status1
bit0 - ACC (0-invalid, 1-valid)
bit1-break (0-invalid, 1-valid)
bit2 - turn left (0-invalid, 1-valid)
bit3 - turn right (0-invaid, 1-valid)
bit4 - forward (0-invalid, 1-valid)
bit5 - backword (0-invalid, 1-valid)
bit6 - left front door (0-Close, 1-Open)
bit7 - right front door (0-close, 1-Open)
status2
bit0 - left mid door (0-close, 1-open)
bit1 - right mid door(0-close, 1-open)
bit2 - left back door(0-close, 1-open)
bit3 - right back door(0-close, 1-open)
x_accel GSensor acceleration, X axis g
y_accel GSensor acceleration, Y axis g
z_accel GSensor acceleration, Z axis g
gsensor_tilt GSensor tilt g
gsensor_impact GSensor impact g
position_accuracy Positioning accuracy m
location_type Location type. 0—location invalid; 1--GPS; 2--BD; 3--Glonass; 4--AGPS; 5--base station location; 6 - WIFI
mob_signal Mobile signal intensity
mob_net_type
Mobile network type:
0 - unknown
3 - 2G
4 - 3G
5 - 4G
6 - 5G
wifi_signal Wi-Fi signal intensity
wifi_net_addr Wi-Fi network address
wifi_gateway Wi-Fi gateway address
wifi_subnet Wi-Fi subnet mask
ssid Wi-Fi ssid
hdN_status
Hard disk N (disk index) status:
0 - unknown
1 - recording
2 - idle
3 - abnormal
4 - full
hdN_size Hard disk N (disk index) size Mega Bytes
hdN_capacity Hard disk N (disk index) balance capacity Mega Bytes
alarms
Alarm status:
bit0—video loss (0: data invalid, 1: data valid)
bit1—motion detection (0: data invalid, 1: data valid)
bit2—video blind (0: data invalid, 1: data valid)
bit3—alarm input trigger(0: data invalid, 1: data valid)
bit4—over speed alarm (0: no trigger, 1: trigger)
bit5—low speed alarm (0: no trigger, 1: trigger)
bit6—emergency alarm (0: no trigger, 1: trigger)
bit7—over time stop (0: no trigger, 1: trigger)
bit8—vibration alarm (0: no trigger, 1: trigger)
bit9—out of GEO fencing alarm (0: no trigger, 1: trigger)
bit10—enter GEO fencing alarm (0: no trigger, 1: trigger)
bit11—exist line alarm (0: no trigger, 1: trigger)
bit12-enter line alarm (0: no trigger, 1: trigger)
bit13—fuel level alarm (0: no trigger, 1: trigger)
video_loss
bit0 - channel 1 video loss indicator (0: no video loss, 1: video loss)
bit1 - channel 2 video loss indicator (0: no video loss, 1: video loss)
bit2 - channel 3 video loss indicator (0: no video loss, 1: video loss)
etc.
motion
Motion detection:
bit0 - channel 1
bit1 - channel 2
etc.
video_blind
Video blind:
bit0 - channel 1
bit1 - channel 2
etc.
alarm_inputs
Alarm inputs triggered:
bit0 - input 1
bit1 - input 2
etc.
in_veh_temp Temperature in vehicle
out_veh_temp Temperature outside of vehicle
motor_temp Motor temperature
device_temp Device temperature
in_veh_hum Humidity in vehicle
out_veh_hum Humidity outside of vehicle
alarm_ec
Event
type code:
0 - unknown
1 - video lost
2 - motion detection
3 - video blind
4 - input trigger
5 - emergency alarm
6 - low speed alarm
7 - over speed alarm
8 - low temperature alarm
9 - high temperature alarm
10 - humidity alarm
11 - parking over time
12 - acceleration alarm
13 - GEO fencing
14 - electronic route
15 - abnormal openclose the door
16 - storage abnormal
17 - fatigue driving
18 - fuel consumption abnormal
19 - illegal ACC
20 - GPS module abnormal
21 - front panel open
22 - Swipe card
23 - IBUTTON
24 - Harsh acceleration
25 - Harsh braking
26 - Low speed warning
27 - High speed warning
28 - Voltage alarm
29 - People counting
30 - ADAS alarm
31 - “Acc on”. Report once at boot
32 Idle
33 Gps antenna break
34 Gps antenna short
35 IO output
36 CAN Bus connection abnormal
37 Towing <
38 Free wheeling
39 RPM exceeds
40 Vehicle Move
41 Trip start(st/et/dtu time same)
42 In trip
43 Trip ends (periodically report after acc off)
44 GPS location recover
45 Video abnormal
768 Trip notification
769 Upgrade notification
1280 Alarm file
281 Timer Snapshot
1282 Alarm file (in visible partition)
1283 ftp file upload notification
alarm_st Event start time
alarm_et Event end time
device_tm Event device time
swipe_card Swipe card number
sc_up
Swipe card information. Onboard/offboard:
1 — Onboard (check in)
2 — Off board (check out)
Else — invalid
sc_ht
Swipe card information. History:
1 — Historical data
2 — Real time data
Else — invalid
total_mileage Total mileage meter
cur_mileage Current day mileage meter
ibutN iButton code. N - iButton number
adas_alarm_type
ADAS:
1 - Forward collision alarm
2 - Lane departure warning
3 -Car distance too near
4 - Pedestrian collision alarm
5 - Frequent lane change alarm
6 - Road sign violate alarm
7 - Harsh Acceleration
8 - Harsh Breaking
9 - Safety Distance
16 - Traffic Sign Recognition
17 - FCW: Forward collision warning
18 - HMW: Headway monitoring warning
19 - Left Lane departure warning
20 - Right Lane departure warning
21 - VB Forward Collision Warning
DMS:
33 - Fatigue driving alarm
34 - Phone call alarm
35 - Smoking alarm
36 - Distracted driving alarm
37 - Driver abnormal alarm
49 - Driver change event
65 - Eye closed
66 - Yawning
67 - Camera cover
68 - Distracted Driving
69 - Seat belt not fastened
70 - No driver
72 - Driver shift
73 - Driver back
80 - Infrared sunglasses
81 - Driver ID identified successfully
82 - Driver ID identified failed
83 - No Driver face detected
85 - Mask not worn
err
Error code:
0 Success
1 Duplicated ID
2 invalid parameter
3 invalid command
4 device busy
5 connection lost
6 related file not exist
7 disk not exist
8 follow up data
9 file search finish
10 Device is not authorized
255 Unknown error
vt
Acceleration alarm, trigger threshold
tt
Acceleration alarm, time threshold
max
Acceleration alarm, Maximum value during the alarm
min
Acceleration alarm, Minimum value in a period
avg
Acceleration alarm, Average value in a period
cur
Acceleration alarm, Current value when reporting
dt_
Acceleration alarm, direction:
1- X direction,
2- Y direction,
3- Z direction,
4- impact,
5- tilt,
6- turn
pre
Acceleration alarm, The value of one second before
drname
Driver name
drid
Driver ID
voltage_N
Vehicle voltage. Double value, in V.
filename
Corresponding file name of recording file. It is usually used in alarm recording playback, and start time/end time is invalid in this mode.
filetype
0 -- unknown
1 -- general recording
2 -- alarm recording
3 -- general snapshot file
4 -- alarm snapshot file
5 -- upgrade file
6 -- log file
7 -- Configuration file
8 -- Black box file
9 -- Visibble alarm video/snapshot
obd_t_mil_N
Accumulated mileage in km.
obd_t_fuel_cons_N
Cumulative fuel consumption in L.
obd_i_fuel_cons_N
Instant fuel consumption in L/km
obd_pwr_N
Vehicle voltage in V
obd_rpm_N
Engine speed in rpm
obd_speed_N
speed, needs *100 for km/h
obd_air_flow_N
Intake air flow in G/s
obd_air_press_N
Intake pressure in Kpa
obd_cool_temp_N
Coolant temperature
obd_int_temp_N
Intake air temperature
obd_eng_load_N
Engine load in %
obd_thr_pos_N
Throttle position in %
obd_rem_oil_N
Remaining oil in %
up0
The number of onbus people, <0 means invalid
dw0
The number of offbus people, <0 means invalid
up1
dw1
cnt_lon
People counting longitude
cnt_lat
People counting latitude
pat
People counting.
0-real time
1-stored and forward (data was resent after network works)
cnt_tm
People countin time
va
People counting, current onbus people number byte is valid or not (device calculated), 0-invalid , 1-valid
swipe_card_rvrsd
Card number, etc.
event_type
Event
type code:
0 - unknown
1 - video lost
3 - video blind
4 - input trigger
5 - emergency alarm
6 - low speed alarm
10 - humidity alarm
13 - GEO fencing
19 - illegal ACC
22 - Swipe card
23 - IBUTTON
25 - Harsh braking
28 - Voltage alarm
30 - ADAS alarm
32 Idle
35 IO output
37 Towing <
38 Free wheeling
39 RPM exceeds
40 Vehicle Move
42 In trip
45 Video abnormal
ft
file type
0 -- unknown
5 -- upgrade file
6 -- log file
8 -- Black box file
fn
file path
For example, “/mnt/sd1/xxxx.264”
ts
Transmission Status
1 -- Start
0 -- End
I/O
1 - Close
2 - Emergency
3 - Front door
4 - Middle door
5 - Back door
6 - Dipped headlight (near light)
7 - High beam (far light)
10 - Right turn light
11 - Left turn light
12 - Brake
13 - Back a vehicle
14 - (Reserved)
15 - The front door close
16 - The middle door close
17 - The back door close
18 - Intercom
19 - Lifting
20 - Seal
21 - Loading
23 - Customer define
24 - Safe to load
32 - Ibutton2
geofence_status
Values description:
0-enter
1-exit
2- over-speed alarm
3- over-speed warning
4-low speed alarm
5-low speed warning
6-forbidden parking engine star
7-forbidden parking engine off
8-overtime stay in geofence
9-Pre-entry
10- Pre-exit
geofence_threshold
The speed value alarm value.
Valid when geofence_status = 2 or 4
Km/h
driver_data
Driver info
bluetooth_data
Bluetooth status
0 -- not connected
1 -- connected
modem_status
Satellite Modem Status
0 — Working normal
1 — Module normal, satellite communication abnormal
2 — Module abnormal
alc_concentr
Alcohol concentration
mg/100ml
trigg_threshold
Trigger threshold
mg/100ml
Grow your business with us
