ICARVISIONS MDVR
ICARVISIONS MDVR
Manufacturer: ICARVISIONS
Number of units
0
Online
Total
Supported in Wialon:
  • Event video
  • Live stream
  • Playback
  • Communication via TCP
The following data should also be added to ICARVISIONS MDVR unit properties section of Wialon GPS tracking software :
Device type: ICARVISIONS MDVR
Unique ID: custom
Specify the following parameters in configuration software or configuration ICARVISIONS MDVR for use in Wialon Hosting :
Server port: 22468
8 units of ICARVISIONS MDVR device type are connected to Wialon Data Center. This represents 0.01% of all Video monitoring connected.
msg_type Type of command
alarm_uid Alarm ID
user_alarm_number User defined alarm number
user_alarm_src Alarm source
user_alarm_name Alarm name
pbutton Shows which button is pressed by driver. Range is 1~8
shock_dir Shock direction. bit0: Harsh Acceleration bit1: Harsh braking. bit2: Impact(collision). bit3: Harsh Corner.
no_signal_chls Channel number. Shows which camera has no signal. According to table from the protocol description.
blind_chls Channel number. Shows which camera is blocked. According to table from the protocol description.
alarm_cur_tmp Temperature when alarm triggered
alarm_low_tmp Lowest temperature
alarm_high_tmp Highest temperature
alarm_disk Disk number
alarm_disk_err Error code
drv_flag Drive flag. The drive flag which cause the upload. 0: center server request real time monitoring command 1: automatically and fixed to upload 2: center request current Position and Status command 3: to sync with the current uploading video
coord_type Coordinate type: 1 character. 0 - WSG84, 1 – Mars coordinates, used by Gaode map, 2- Baidu coordinates
pos_type Position type: 1 character. 0- GPS, 1- base station location, 2- WIFI position
st1 1 byte of component status
st2 2 byte of component status
st3 3 byte of component status
st4 4 byte of component status
st5 5 byte of component status
st6 6 byte of component status
st7 7 byte of component status
st8 8 byte of component status
dev_temp Device temperature
eng_temp Engine temperature
cab_temp Cabin temperature
mileage Mileage
fuel_cons Fuel consumption
stop_dur Stop duration
Grow your business with us
