MDVR-X3A-4CH
MDVR-X3A-4CH
Manufacturer: Streamax Technology
Number of units
0
Online
0
Total
The following data should also be added to MDVR-X3A-4CH unit properties section of Wialon GPS tracking software :
Device type: MDVR-X3A-4CH
Unique ID: custom
Specify the following parameters in configuration software or configuration MDVR-X3A-4CH for use in Wialon Hosting :
Server port: 21011
0 units of MDVR-X3A-4CH device type are connected to Wialon Data Center. This represents 0% of all Video monitoring connected.
temp_int Device temperature ℃
temp_ext Environment temperature ℃
line_num Line number
driver_num Driver number
next_st_num Next station number
stop_sign
Stop sign:
0 - bus is in the stop
1 - means the bus is between two stops.
When the bus arrives the stop and didn’t leave, the sign is 0, otherwise it’s 1
people_num The number of people on the bus.
For correct device performance please indicate the same timezone in Wialon account settings, in the device itself and in the advanced settings of the device type in Wialon (wrench icon near the device type).
Grow your business with us
