What fleet operators really want — and how to show you can deliver
What Fleet Operators Really Want — and How to Show You Can Deliver
A fleet operator comes to you with what sounds like a straightforward request: “Can you put our vehicles on a map?” Another asks for cameras, fuel monitoring, or a way to keep track of drivers’ hours. They may have seen another company use the technology and decided they need it too. Some clients arrive with a broader goal, such as cutting costs or improving visibility, but there’s still plenty to find out before you can suggest a useful solution.
As a Wialon partner, you build solutions powered by Wialon, combining our products with the hardware, integrations, and services your clients need. Understanding what prompted their request helps you decide how those parts should fit together. It also gives you the beginnings of a story: a picture of how their operation could work, with your help, once the solution is in place.
Here, we draw on contributions from our partners Unicomm and Geologistic to the marketing insights session at the Wialon community reunion in Mexico City, alongside an example from our case study library, to explore how you can develop that picture with a client and use it to sell your solution.
Find the idea behind the request
Start with what led the fleet to you. If they’re asking for cameras, what do they want to be able to see, and when would they use the footage? If they want to cut costs, where do they suspect money is being lost? Ask them to walk you through a recent situation they’d like to handle differently. The people involved, the tools they use, and the points where work gets held up will tell you much more about the project than the initial request alone.
The same applies when a client asks for “something with AI.” Ask which task they want to make easier, what information their team works with, and where they spend time checking or interpreting it. Choose a specific scenario to explore, then agree how you would judge the result: time spent on the task, errors, or the ability to act on the information. That gives you both a way to assess whether AI would help and what a useful demo should show.
__CTA_BANNER_AI001EN__
Lilian Mejia Coronel, Marketing Manager at Unicomm, describes fleet operators looking for visibility and the ability to respond when something happens on the road. She also points out that even promises such as fewer incidents or less downtime can sound vague until they’re grounded in the fleet’s own experience. Give those ideas meaning in the operation you’re discussing.
Imagine a delivery company whose dispatchers spend hours calling drivers because customers keep asking where their deliveries are. The request for a map starts to make sense. So does the bigger idea: dispatchers should have enough information to handle routine location inquiries themselves, leaving drivers to get on with deliveries. That gives you something specific to work toward together.
Then work out how much the solution should cover. Tracking may be enough for the immediate problem, or the conversation may uncover a need to connect vehicle information with orders or rethink part of the dispatch process. You might expand the proposal, suggest a later phase, or recommend a simpler setup than the client originally had in mind. Each choice should follow from what you’ve learned about their work.
GeoLogistic provides a useful example of how far that understanding can take a solution. The company uses Wialon APIs to connect its own ERP with telematics data, extending its offer into areas such as maintenance, documents, fuel, and warehouse processes. The team first discusses the client’s operation, existing tools, and goals.
What Fleet Operators Really Want — and How to Show You Can Deliver (3)
Give the idea a story
A story gives the client a way to follow the change you’re proposing. Take the delivery company: one of its customers calls asking where a delivery vehicle is, and the dispatcher checks its position and answers while they’re still on the phone. If the question needs information the map can’t provide, they contact the driver knowing more about the situation. The aim is to reduce routine calls so dispatchers can spend more time on deliveries that need attention. Walk through this scenario together to see whether it would help the dispatch team.
There’s room for them to question that picture and add to it. Can dispatchers easily identify the right vehicle? Do they need information from another system? Who should be able to see it? As you work through the details, the client can see how the concept would fit their company. Your contribution becomes clear through the choices you make together, from selecting suitable hardware to arranging the information around the team’s tasks.
A demo can follow the same story. Use a situation the client recognizes and show how someone would handle it with the solution you’re proposing. Give them time to try the relevant steps and explain where you would adapt the setup for their operation. Our Technical Growth team can help you prepare the demo environment and choose use cases that fit the project.
Show what happened for another client
Once a customer can picture the change, they’ll want a reason to believe it can happen. As Unicomm’s Lilian Mejia Coronel puts it, “Demos help clients visualize the solution, but real client cases help them believe in it.” This is why we tell the stories behind partner projects in our case study library. Each case explains the challenge a company faced, what the partner built, and what happened after the solution went into use.
For example, in our TaxiView case study, a UK technology provider for the taxi and private hire sector had to bring vehicles back to base to retrieve CCTV recordings. Its Wialon partner ACSS combined its own in-vehicle CCTV hardware with Wialon Hosting, making footage available remotely. ACSS reports up to 80% faster incident response. The story connects the technology to a recognizable change in how incidents are handled.
__CTA_BANNER_TAXICASEEN__
Use the same approach when documenting your projects. Explain the original problem and how the solution works, including how the hardware, Wialon, your own software, or other integrations fit together. A simple architecture diagram can help when there are several components. Then show what changed for the fleet. If a task takes less time, give the comparison and measurement period. A client’s own account of what became easier adds a perspective that the figures alone can’t provide.
When sharing a case with a prospect, explain why you chose it and where their situation differs. Examples from our library demonstrate what’s possible with Wialon; your own cases show the experience your team brings to the project. Discuss which parts of the approach would work for this client and what you would change. Help them assess how the example applies to their own project.
What Fleet Operators Really Want — and How to Show You Can Deliver (2)
Help the client turn the picture into reality
By now, you’ve spent time understanding the client and helped them imagine a way of working they’d like to have. They also need to know you’ll help them get there. Unicomm identifies concerns about implementation, resistance to change, and staff adaptation as reasons a decision can stall. Someone may like the proposal and still worry that their team will struggle with it or that they’ll be left to work things out after installation.
Make the guidance you’ll provide part of the conversation. Introduce the people who will work with them and explain how you’ll help their staff learn the tasks that matter. For the delivery company, that could mean starting with a few dispatchers, working through the questions they handle every day, and adjusting the setup based on their experience. Agree how you’ll check whether it’s helping before extending it to the rest of the team.
How you handle uncertainty matters too. Explain what you need from the client, give realistic expectations for the launch, and be open about anything that needs more work. Set out how they can get help afterward and when you’ll review progress together. Someone who struggles with a new workflow should know whom to call and what help to expect. These details make it easier for the client to see you as the company that will stay involved as the project develops.
Wialon helps you prepare your team and support fleets after launch. Our Technical Growth team provides project guidance and training. For day-to-day technical questions, support is available 24/7, with human specialists working in English, Spanish, French, Portuguese, and Russian, alongside AI-powered assistance from Lona. In September 2026, half of support replies reached partners within 6 minutes. Read more about how AI and human expertise work together in Wialon.
Your dedicated Partner Success Manager is also there to discuss project plans and commercial questions. Build that support into your own preparation so you can explain confidently how you’ll look after the client.
Help your contact make the case internally
Your contact may be ready to go ahead while their colleagues still have questions. GeoLogistic describes projects slowing down after trials, meetings, and follow-up because the people involved can’t reach agreement internally. Help your contact explain the proposed change to the rest of the company. They should be able to describe what you’re trying to achieve together and have enough detail for colleagues to judge the project from their own perspective.
For the delivery company, that could mean preparing answers to questions like these:
  • Operations: How will dispatchers use the information, and which tasks will change?
  • Finance: What are the setup and ongoing costs, and how will the fleet measure the value of time saved?
  • Security: Who can receive vehicle-location information, and how will dispatchers verify requests?
  • IT: How will the solution fit the existing software, and who will manage integrations and access?
  • Management: Is the expected improvement worth the investment, and can you deliver and support it?
The central idea stays the same: make routine location checks easier for dispatchers. You’re helping each team understand what that would involve for them. Give your contact material they can share without you in the room, including a clear proposal, a relevant client case, and practical information about costs and implementation. Offer to join a conversation with their colleagues when it would help. Your contact shouldn’t have to become a telematics expert to get the project moving.
What Fleet Operators Really Want — and How to Show You Can Deliver (4)
Bring the same thinking into your marketing
So far, we’ve focused on what happens when a client comes to you. The same approach can help attract that conversation in the first place. GeoLogistic’s Edgar Zamora describes prospects researching suppliers and looking for references before making contact. GeoLogistic now shares practical knowledge on its website that it once kept internal. Your content gives people a chance to understand your approach and decide whether you’re someone they’d like to speak to.
Start with situations your clients recognize. A company transporting valuable cargo will have different questions about cameras from a fleet looking for material to use in driver coaching. A short video could show how a manager finds and reviews footage when cargo is reported missing. An article about reviewing driving events with staff could help the second company. Useful explanations let people learn about a possible solution while getting a feel for your expertise.
Carry that thinking into your solution pages. A visitor may arrive looking for a particular feature, so make it easy to find and understand. Then develop the picture around it: explain how it could fit their work, show a relevant client story, and describe how you would help them get started. Introduce the people who would be involved. Someone reading the page should begin to understand the service they’d get from your company as well as the technology they’d use.
Draw on our marketing materials, including presentations and visual assets, when preparing your content. Adapt these materials around your own projects and the fleets you want to reach, so they explain the solution and service your team will deliver.
When a client gets in touch asking for a map, they may need a fairly simple setup, or the conversation may lead to a much wider project. Taking the time to understand the idea behind the request helps you build a solution they can see working in their business, with a clear sense of how you’ll help them make it happen.
__HIGHLIGHTED_TEXT_001EN__
Want to build fleet digitalization solutions with Wialon? Request a demo. We’ll walk you through our product portfolio, explore the options for your projects, and explain how partnering with Wialon can help you grow your business.
Cover 1600x896 (8)
How Wialon’s AI tools help service providers and fleets
Learn more
Uk Taxi Fleet
80% faster incident response: Integrated video monitoring for UK taxi fleets
Learn more
6414342930e61
Alena Kalionava
Alena is the Content Marketing Team Lead at Wialon. She leads a talented team that produces a wide range of content — from blog posts and case studies to dynamic presentations — that empower and inform Wialon partners and fleet managers alike.
