Galileosky 10
Galileosky 10
Manufacturer: Galileosky
Number of units
2127
Online
4712
Total
Features Galileosky 10:
  • 2G
  • 3G
  • 4G/LTE
  • Blackbox
  • BLE enabled
  • Dual SIM
  • GLONASS support
  • Sending data to multiple servers
  • Built-in odometer
  • Voice calls
  • Wi-Fi positioning
Supported in Wialon:
  • Accelerometer
  • ADC sensors
  • CAN-bus support
  • Communication with driver
  • ECO driving
  • Remote management via GPRS
  • Driver identification
  • Digital sensors
  • LBS
  • Remote management via SMS
  • Communication via TCP
  • Communication via UDP
The following data should also be added to Galileosky 10 unit properties section of Wialon GPS tracking software :
Device type: Galileosky 10
Unique ID: imei
Specify the following parameters in configuration software or configuration Galileosky 10 for use in Wialon Hosting :
Server port: 22481
4712 units of Galileosky 10 device type are connected to Wialon Data Center. This represents 0.21% of all AVL Hardware connected.
acc1 input ADC 5
acc2 Acceleration
acc Acceleration
accident_codeN Accident code N
accidentN The level of accident N
acc_trigger Acceleration status
accX X-axis acceleration
M/S2
accY Y-axis acceleration
M/S2
accZ Z-axis acceleration
M/S2
adcX Analog sensor, X - number of sensor
adcX_s Signed analog sensor, X - number of sensor
adc9 RS232 0
adc10 RS232 1
alarm_codeN Zone N alarm code
alarm_typeN Zone N alarm type
blast_air_tempN Zone N blast air temperature °C
braking_accel Braking
M/S2
canX Value of CAN, X - identifier of a message
course_accel Acceleration
M/S2
dinN Refrigerator's digital input N value
ds1923_humidityX humidity sensor DS1923, X - number of sensor %
ds1923_tempX Temperature sensor DS1923, X - number of sensor °C
evap_tempN Zone N evaporator temperature °C
fms_spn_1611
SAE J1939 SPN 1611. Drive recognize
fms_spn_1612
SAE J1939 SPN 1612. Driver 1 working state
fms_spn_1613 SAE J1939 SPN 1613. Driver 2 working state
fms_spn_1614
SAE J1939 SPN 1614. Overspeed
fms_spn_1615
SAE J1939 SPN 1615. Driver 1 card
fms_spn_1616
SAE J1939 SPN 1616. Driver 2 card
fms_spn_1617
SAE J1939 SPN 1617. Driver 1 time rel. states
fms_spn_1618
SAE J1939 SPN 1618. Driver 2 time rel. states
fms_spn_1619
SAE J1939 SPN 1619. Direction indicator
fms_spn_1620
SAE J1939 SPN 1620. Tachograph performance
fms_spn_1621
SAE J1939 SPN 1620. Handling information
fms_spn_1622
SAE J1939 SPN 1621. Tachograph event
fuel_level Fuel level in the tank %
gprs_answer Response device
gps_mileage Total mileage according to the GPS/GLONASS modules Meter
gsm_status GSM signal quality
hdop Horizontal accuracy
hours_counterN Counter N hours till service h
hours_electric Motohours. Electric h
hours_engine Motohours. Engine h
hours_standby Motohours. Standby h
hours_switch Motohours. Switch h
hours_vehicle Motohours. Vehicle h
ibutton_code Identification number of the first key iButton
ibuttons Ibutton keys status
omni_tmp_X Omnicom sensor, X - number of sensor
pressX_pci_data Pressure in atm, X - number of sensor
pressX_status_battery Sign of low battery charge the internal battery, X - number of sensor
pressX_status_error Reason parcel packet from the sensor, X - number of sensor
pressX_tmp Temperature, X - number of sensor
pwr_ext Voltage of external power supply Volt
pwr_int Power supply internal battery Volt
refr_type Refrigerator unit type. 1 – DataCOLD, 2 – ThermoKing, 3 – Mitsubishi
return_air_tempN Zone N return air temperature °C
rs485ex_X_lvl Fuel sensor connected via rs485
rs485ex_X_tmp Temperature sensor connected via rs485 °C
rs485_fls02 Fuel sensor connected via rs485
rs485_fls12 Fuel sensor connected via rs485
rs485_fls22 Fuel sensor connected via rs485
rs485tmp_X Temperature sensor connected via rs485, X - number of sensor
set_tempN Zone N set temperature
soft Current version of firmware
statusN Zone N status
taho Engine speed
temp_aqua Coolant temperature °C
temp_int temperature of the terminal °C
temp_sensorN Temperature sensor N value °C
tempX Temperature sensor, X - number of sensor °C
trailer_id Identification number of the second key iButton
trailer_id_code Identification number of the second key iButton as decimal
turn_accel Acceleration on the turn
M/S2
valid
Valid of coordinates (0-valid, 1-invalid, 2-LBS coordinates, 15-GPS module is off )
vertical_accel Vertical acceleration
M/S2
vib_N
The relative intensity of vibration analysis with N unique identifier of a characteristic feature
user_d User data
taho_type Tachograph type
taho_state
Tachograph connection state:
0 - not connected
1 - not authorised
2 - authorised
taho_mode
Сurrent mode of the tachograph:
0 - normal mode
1 - control mode
2 - calibration mode
3- enterprise mode
taho_speed Vehicle speed km/h
taho_trip Trip distance
taho_flags
Flags of the tachograph status:
0 - igntion
1 - switched ground (for ADR)
2 - special condition of "ferry / train"
taho_dN_activity
Current activity of the N driver:
0 – rest
1 – availability
2 – work
3 – drive
taho_dN_cardtype
Card type of the N driver:
1 – Driver card
2 – Workshop card
3 – Controller card
4 – Company card
taho_dN_activ_tm The time spent in the current mode. min
taho_dN_driv_tm Accumulated driving time in a day. min
taho_dN_restl_tm Сontinuous driving time since the last rest. min
taho_dN_card_num Card number.
wheel_tempN Temperature in the wheel with N index °C
rec_sn Number of an archive record
can_r#
Tag value
For tag with value range (HEX) 0xC4 - 0xD2 , 0xD6 - 0xDA, 0xDB - 0xDF
# = Tag number (DEC) - 196
can8bitr#
Tag value
For tag with value range (HEX) 0xA0 - 0xAF
# = Tag number (DEC) - 144
can16bitr#
Tag value
For tag with value range (HEX) 0xB0 - 0xB9
can32bitr#
Tag value
For tag with value range (HEX) 0xF0 - 0xF9
modbus_N
Modbus External Tags. N = 0...63
bt_N
Bluetooth External Tags. N = 0...63
press#_pci_data
Tyre pressure
atm
press#_tmp
Tyre temperature
C
press#_gsm
Connection error
press#_status_battery
Low battery error
press#_status_error
Send data reason
wifi_modem_status Current status of WiFi modem
wifi_error_code Error code from WiFi modem
gsm_modem_status Current status of GSM modem
network_reg_status Network registration status
gprs_status Current GPRS connection status
free_ram Available RAM memory bytes
archive_total_packets Total number of archived packets
archive_sent_main Number of main archive packets sent
archive_sent_additional Number of additional archive packets sent
archive_last_record Last recorded archive entry
wifi_mac WiFi interface MAC address
ble_mac Bluetooth interface MAC address
last_reset_time Timestamp of last device reset
reset_reason Reason for last device reset
reset_reason_count Number of times this reset reason has occurred
signal_to_noise_ratio_avg Average signal to noise ratio dB
sd_status SD card status
sd_errors Number of SD card errors
collector_total_packets Total number of collector packets
collector_sent_main Number of main collector packets sent
collector_reserved Reserved collector space
client1_mac MAC address of client device 1
client2_mac MAC address of client device 2
client3_mac MAC address of client device 3
additional_status
  • Bit 0 is the connection state to the primary
    server. 1 is “connected”, 0 is “not connected”.
  • Bit 1 is GPRS session status. 1 is “on”, 0 is “off”.
  • Bit 2 is the sign of GSM jamming.
    1 is “GSM jamming detected”, 0 is “no jamming detected”.
  • Bit 3 is the connection state to the additional server.
  • Bit 4 is the sign of GPS/GLONASS jamming. 1 is “jamming detected”, 0 is “no jamming detected”
  • Bit 5 is sign of connection to cable USB of device USB. 1 is “connected”, 0 is “not connected.
  • Bit 6 – sign of SD car presence in device. 1 – present, 0 – absent.
Grow your business with us
