Lorawan E1374 Tracker ONE SW
Manufacturer: Comtac
Number of units
Online
53
Total
Supported in Wialon:
  • Communication via TCP
The following data should also be added to Lorawan E1374 Tracker ONE SW unit properties section of Wialon GPS tracking software :
Device type: Lorawan E1374 Tracker ONE SW
Unique ID: imei
Specify the following parameters in configuration software or configuration Lorawan E1374 Tracker ONE SW for use in Wialon Hosting :
Server port: 21785
53 units of Lorawan E1374 Tracker ONE SW device type are connected to Wialon Data Center. This represents 0% of all AVL Hardware connected.
gps_epe GPS EPE m
payl_ver Payload version
data_stat Status from DATA messages
bat_volt Battery voltage mV
dev_type Device type, 00: Debug mode, 01: Container Positioning, 02: Device Usage Detection, 03: Tracking
acc_on_thres AccOn Thres mg
acc_on_count AccOn count
acc_max_on_all AccMaxOnAll mg
acc_min_on_all AccMinOnAll mg
acc_min_on_max AccMinOnMax mg
mic_on_thres MicOn Thres dBSPL
mic_on_count MicOn count
mic_max MicMax dBSPL
mic_min MicMin dBSPL
conf_stat Status from CONFIG messages
debug_int Debug Interval 1..240 min
conf_int
Config. Detect Interval 1..240
hours
sens_int Sense Interval 1..240 min
gps_int GPS Interval 5..240 min
main_ver Application Main Version
sub_ver Application Sub Version
gps_tr_val
GPSTries Value , Number of GPS fixes needed for a valid position (min 5 max 20, unsigned)
sens_stop_int SenseStop Interval, 0..240 in minutes (unsigned) [Start or Stop must be non-ZERO!]
sens_start_int SenseStart Interval, 0..240 in minutes (unsigned) [Start or Stop must be non-ZERO!]
Grow your business with us
