Teltonika FM4100
Teltonika FM4100
Manufacturer: Teltonika
Number of units
33
Online
79
Total
The following data should also be added to Teltonika FM4100 unit properties section of Wialon GPS tracking software :
Device type: Teltonika FM4100
Unique ID: imei
Password to access the object: Configuration password to access the object
Specify the following parameters in configuration software or configuration Teltonika FM4100 for use in Wialon Hosting :
Server port: 20127
79 units of Teltonika FM4100 device type are connected to Wialon Data Center. This represents 0% of all AVL Hardware connected.
battery_charge Battery charge
canN CAN specific data (I/O property 145-154)
counter1 Fuel Counter (I/O property 76)
driver_code
Shows the moment of binding/unbinding a driver:
1 - binding
0 - unbinding
driver_status Garmin driver status
gsm GSM signal strength level 0 (lowest) – 5 (highest) (I/O property 21)
hdop Horizontal Dilution of Precision (I/O property 20 or 182)
last_driver_status Last Garmin driver status
paramN Value of special I/O property, where N - ID of property
pdop Position Dilution of Precision (I/O property 22)
priority
Message Priority:
0 - low
1 - high
2 - panic
3 - security
pwr_ext Power supply voltage (I/O property 66) V
pwr_int Battery voltage (I/O property 67) V
vdop Vertical Dilution of Precision (I/O property 21)
You can also download an example of Teltonika FM4100 configuration file to connect it to Wialon GPS tracking software.
Instruction on configuring the device via TCP.
You can also download an example of object configuration file for Teltonika FM4100 to be used in Wialon GPS tracking software. When creating an object, import this configuration file by selecting "Import from File" option. This way you will create a pre-configured object with some sensors. Do not forget to specify the unique Id of Your device.
For communication via SMS, enter "login password" defined for the device and divided by the space in the "Device access password" field of the GPS unit in Wialon GPS tracking software.
To support «24 SMS in 1» mode, the interval between the points should be 900 seconds as it is on the server, i.e. the value should be 900000 ms in the device configuration.
I/O elements are additional source of information and are registered together with GPS data.
Grow your business with us
