Teltonika FMB920
Teltonika FMB920
Manufacturer: Teltonika
Number of units
106519
Online
243998
Total
Features Teltonika FMB920:
  • 2G
  • Blackbox
  • BLE enabled
  • GLONASS support
  • Sending data to multiple servers
  • Built-in odometer
Supported in Wialon:
  • Accelerometer
  • ADC sensors
  • Remote management via GPRS
  • Digital sensors
  • LBS
  • SMS sending of data
  • Remote management via SMS
  • Alarm button
  • Modification of the "speed" parameter
  • Communication via TCP
  • Communication via UDP
The following data should also be added to Teltonika FMB920 unit properties section of Wialon GPS tracking software :
Device type: Teltonika FMB920
Unique ID: imei
Specify the following parameters in configuration software or configuration Teltonika FMB920 for use in Wialon Hosting :
Server port: 21328
243998 units of Teltonika FMB920 device type are connected to Wialon Data Center. This represents 10.82% of all AVL Hardware connected.
gsm GSM signal strength level 0 (lowest) – 5 (highest) (I/O property 21)
hdop Horizontal Dilution of Precision (I/O property 20 or 182)
pdop Position Dilution of Precision (I/O property 181)
mcc Mobile country code
mnc Mobile network code
lac Location area code
cell_id Cell ID
pwr_ext Power supply voltage (I/O property 66) V
pwr_int Battery voltage (I/O property 67) V
io_N
Value of special I/O property, where N - property ID in AVL packet
Detiled description is placed in the Specification
beacon_"beacon_id"_temp
Where beacon_id - id of beacon
Celsius
beacon_"beacon_id"_hum
Percent
beacon_"beacon_id"_angle_pitch
beacon_"beacon_id"_angle_roll
beacon_"beacon_id"_bat
Volts
beacon_"beacon_id"_rssi
beacon_"beacon_id"_mov_sensor
How to use Teltonika FMB920 in Wialon
Detailed description of parameters is available in the document.
Grow your business with us
