Teltonika FMC800
Teltonika FMC800
Manufacturer: Teltonika
Number of units
1288
Online
1982
Total
Features Teltonika FMC800:
  • 2G
  • 4G/LTE
  • BLE enabled
  • GLONASS support
  • Sending data to multiple servers
Supported in Wialon:
  • Accelerometer
  • ECO driving
  • Remote management via GPRS
  • Digital sensors
  • LBS
  • SMS sending of data
  • Remote management via SMS
  • Modification of the "speed" parameter
  • Communication via TCP
  • Communication via UDP
The following data should also be added to Teltonika FMC800 unit properties section of Wialon GPS tracking software :
Device type: Teltonika FMC800
Unique ID: imei
Specify the following parameters in configuration software or configuration Teltonika FMC800 for use in Wialon Hosting :
Server port: 22387
1982 units of Teltonika FMC800 device type are connected to Wialon Data Center. This represents 2.37% of all OBD trackers connected.
gsm GSM signal strength level 0 (lowest) – 5 (highest) (I/O property 21)
hdop Horizontal Dilution of Precision (I/O property 20 or 182)
pdop Position Dilution of Precision (I/O property 181)
mcc Mobile country code
mnc Mobile network code
lac Location area code
cell_id Cell ID
pwr_ext Power supply voltage (I/O property 66) V
pwr_int Battery voltage (I/O property 67) V
io_N
Value of special I/O property, where N - property ID in AVL packet
Detiled description is placed in the Specification
driver_code_reversed reverse value of ibutton
but_pan_stat
Button panel status,
OFF_ROAD - Vehicle On Road
ON_ROAD - Vehicle Off Road
START_TRIP - Vehicle Trip Started
ON_SCENE - Vehicle On Scene
ON_BOARD - Vehicle On Board
HOS_IN - Vehicle Hospital In
HOS_OUT - Vehicle Hospital Out
END_TRIP - Vehicle trip Completed
STOP_TRIP - Vehicle Trip canceled
fms_#1_#2 FMS Gateway data, where #1 - message id, #2 - signal number
Grow your business with us
