Teltonika FMU130
Teltonika FMU130
Manufacturer: Teltonika
Discontinued
Number of units
2951
Online
15051
Total
Features Teltonika FMU130:
  • 3G
  • Blackbox
  • GLONASS support
  • Sending data to multiple servers
Supported in Wialon:
  • Accelerometer
  • ADC sensors
  • Remote management via GPRS
  • Digital sensors
  • SMS sending of data
  • Modification of the "speed" parameter
  • Communication via TCP
  • Communication via UDP
The following data should also be added to Teltonika FMU130 unit properties section of Wialon GPS tracking software :
Device type: Teltonika FMU130
Unique ID: imei
Specify the following parameters in configuration software or configuration Teltonika FMU130 for use in Wialon Hosting :
Server port: 21858
15051 units of Teltonika FMU130 device type are connected to Wialon Data Center. This represents 0.67% of all AVL Hardware connected.
gsm GSM signal strength level 0 (lowest) – 5 (highest) (I/O property 21)
hdop Horizontal Dilution of Precision (I/O property 20 or 182)
pdop Position Dilution of Precision (I/O property 181)
mcc Mobile country code
mnc Mobile network code
lac Location area code
cell_id Cell ID
pwr_ext Power supply voltage (I/O property 66) V
pwr_int Battery voltage (I/O property 67) V
io_N
Value of special I/O property, where N - property ID in AVL packet
Detiled description is placed in the Specification
Detailed description of parameters is available here.
Grow your business with us
