- 2G
- 4G/LTE
- Blackbox
- BLE enabled
- Dual SIM
- GLONASS support
- Accelerometer
- CAN-bus support
- Remote management via GPRS
- Modification of the "speed" parameter
- Communication via TCP
- Communication via UDP
The following data should also be added to Teltonika FMC150 unit properties section of Wialon GPS tracking software :
| Device type: | Teltonika FMC150 |
| Unique ID: | imei |
Specify the following parameters in configuration software or configuration Teltonika FMC150 for use in Wialon Hosting :
| Server port: | 22371 |
19799 units of Teltonika FMC150 device type are connected to Wialon Data Center. This represents 0.88% of all AVL Hardware connected.
