- 2G
- 4G/LTE
- Blackbox
- BLE enabled
- Dual SIM
- GLONASS support
- Accelerometer
- ADC sensors
- Camera connection
- CAN-bus support
- Garmin support
- Remote management via GPRS
- Driver identification
- Digital sensors
- LBS
- MobilEye support
- Remote management via SMS
- Modification of the "speed" parameter
- Tachograph file download
- Communication via TCP
- Communication via UDP
The following data should also be added to Teltonika FMC650 unit properties section of Wialon GPS tracking software :
| Device type: | Teltonika FMC650 |
| Unique ID: | imei |
Specify the following parameters in configuration software or configuration Teltonika FMC650 for use in Wialon Hosting :
| Server port: | 22430 |
12159 units of Teltonika FMC650 device type are connected to Wialon Data Center. This represents 0.54% of all AVL Hardware connected.
