Teltonika FMM640
Teltonika FMM640
Manufacturer: Teltonika
Number of units
56
Online
120
Total
Features Teltonika FMM640:
  • 2G
  • 4G/LTE
  • BLE enabled
  • Dual SIM
  • GLONASS support
  • Sending data to multiple servers
  • Voice calls
Supported in Wialon:
  • Accelerometer
  • ADC sensors
  • Camera connection
  • CAN-bus support
  • Garmin support
  • Remote management via GPRS
  • Driver identification
  • Digital sensors
  • LBS
  • MobilEye support
  • SMS sending of data
  • Remote management via SMS
  • Alarm button
  • Modification of the "speed" parameter
  • Tachograph file download
  • Communication via TCP
  • Communication via UDP
The following data should also be added to Teltonika FMM640 unit properties section of Wialon GPS tracking software :
Device type: Teltonika FMM640
Unique ID: imei
Specify the following parameters in configuration software or configuration Teltonika FMM640 for use in Wialon Hosting :
Server port: 22111
120 units of Teltonika FMM640 device type are connected to Wialon Data Center. This represents 0.01% of all AVL Hardware connected.
gsm GSM signal strength level 0 (lowest) – 5 (highest) (I/O property 21)
hdop Horizontal Dilution of Precision (I/O property 20 or 182)
pdop Position Dilution of Precision (I/O property 181)
mcc Mobile country code
mnc Mobile network code
lac Location area code
cell_id Cell ID
pwr_ext Power supply voltage (I/O property 66) V
pwr_int Battery voltage (I/O property 67) V
io_N
Value of special I/O property, where N - property ID in AVL packet
Detiled description is placed in the Specification
driver_code_reversed reverse value of ibutton
vin Vehicle identification number for FMS elements
vin2 Vehicle identification number for tachograph data elements
id_code Identification Code
tpms_source
TPMS Data Source:
0: Data from TPMS
1: Data from Repeater, Repeater (Signal Enhancer)
tpms_type
TPMS Type:
66: Passenger type TPMS, 637.5 KPa Max
6A: Truck Type TPMS, 1277.5 KPa Max
tpms_id TPMS ID
vehicle_type Vehicle Type
tire_number Tire number
location_code Location Code
tire_pressure_val Pressure Value
pressure_scale
Pressure Scale:
1: PSI
2: KPa
4: Bar
8: Kg/cm2
tire_temp Temperature °C
tire_temperature_error Temperature error
tire_battery_abnormal Battery abnormal
tire_low_pressure Pressure too low
tire_high_pressure Pressure too high
tire_pressure_relief Pressure relief
tire_signal_loss Signal loss
Grow your business with us
