CARVIS MD-444HDD
CARVIS MD-444HDD
Manufacturer: CARVIS
Number of units
Online
Total
Features CARVIS MD-444HDD:
  • 4G/LTE
  • Blackbox
  • GLONASS support
The following data should also be added to CARVIS MD-444HDD unit properties section of Wialon GPS tracking software :
Device type: CARVIS MD-444HDD
Unique ID: custom
Specify the following parameters in configuration software or configuration CARVIS MD-444HDD for use in Wialon Hosting :
Server port: 22220
4 units of CARVIS MD-444HDD device type are connected to Wialon Data Center. This represents 0.01% of all Video monitoring connected.
param_id_#
Parameter value
event_#
Event
alarm_flag
Alarm flag (Bits1-32):
Bit2: 1: Over speed alarm
Bit4: 1: Risk warning
Bit12: 1: Camera malfunction
Bit14: 1: Over speed warning
Bit16-Bit18: Reserve
Bit20: 1: Timeout parking
Bit24: 1: Off track alarm
Bit30: 1: Collision warning
Bit31: 1: Rollover warning
state_flag
Status (Bits 1-32):
Bit1: 0: ACC off; 1: ACC on
Bit7-Bit8: Reserve
Bit23-32: Reserve
odometer
Odometer
fuel_volume
Fuel volume
speed_drvng_rec
Speed driving rec
alarm_event_id
Alarm event ID
overspeed_alarm
Overspeed alarm
position_type
Position type
section_id
Section ID
route_alarm
Route alarm
direction
Direction
driving_time_alarm
Driving time alarm
driving_time
Driving type
driving_results
Driving results
video_alarm
Video alarm
video_signal_loss_alarm
Video signal loss alarm
video_signal_block_alarm
Video signal block alarm
memory_fault_alarm
Memory fault alarm
abnormal_driving_alarm
Abnormal driving alarm
veh_signal_status
Veh. signal status
user_msg
User mesage
Grow your business with us
