Richmor RCM-MDRSP5
Number of units
Online
27
Total
Features Richmor RCM-MDRSP5:
  • 4G/LTE
  • Blackbox
Supported in Wialon:
  • Event video
  • Live stream
  • Manual video saving
  • Playback
  • Communication via TCP
The following data should also be added to Richmor RCM-MDRSP5 unit properties section of Wialon GPS tracking software :
Device type: Richmor RCM-MDRSP5
Unique ID: custom
Specify the following parameters in configuration software or configuration Richmor RCM-MDRSP5 for use in Wialon Hosting :
Server port: 22752
27 units of Richmor RCM-MDRSP5 device type are connected to Wialon Data Center. This represents 0.04% of all Video monitoring connected.
param_id_#
Parameter value
event_#
Event
alarm_flag
Alarm flag (Bits1-32):
Bit2: 1: Over speed alarm
Bit4: 1: Risk warning
Bit12: 1: Camera malfunction
Bit14: 1: Over speed warning
Bit16-Bit18: Reserve
Bit20: 1: Timeout parking
Bit24: 1: Off track alarm
Bit30: 1: Collision warning
Bit31: 1: Rollover warning
state_flag
Status (Bits 1-32):
Bit1: 0: ACC off; 1: ACC on
Bit7-Bit8: Reserve
Bit23-32: Reserve
odometer
Odometer
fuel_volume
Fuel volume
speed_drvng_rec
Speed driving rec
alarm_event_id
Alarm event ID
overspeed_alarm
Overspeed alarm
position_type
Position type
section_id
Section ID
route_alarm
Route alarm
direction
Direction
driving_time_alarm
Driving time alarm
driving_time
Driving time
driving_results
Driving results
video_alarm
Video related alarm
Bit 1 Video signal loss alarm
Bit 5 Over passengers alarm
Bit 8-32 Reserved
video_signal_loss_alarm
video_signal_block_alarm
memory_fault_alarm
abnormal_driving_alarm
Bit1:fatigue;
Bit2:call;
Bit3:smoking;
veh_signal_status
Veh. signal status
user_msg
User mesage
veh_stat
info_id
Additional information ID
  4. 0x14 - Video-related alarm
  7. 0x17 - Memory fault alarm
alm_time
Alarm time threshold
sec
alm_thre1
Warning threshold 1
alm_thre2
Warning threshold 2
workstate
Workstate,
0x01: normal work
0x02: standby mode
0x03: Upgrade maintenance
0x04: Device is abnormal
0x10: Disconnect
alarm_status
Alarm status, bits(1-32)
bit1: cameraabnormal
bit2: Main memory exception
bit5: abnormal speaker
bit6: Abnormal battery
bit7~bit10:reserved
bit13~bit32:reserved
alm_lvl
Warning level:
  • 0x01: Level 1 warning
  • 0x02: Level 2 warning
alm_id
sign_stat
Sign status.
  • 0x00: Not available
  • 0x01: Start sign
  • 0x02: End sign
veh_ah_spd
km/h
veh_ah_dst
dev_type
Deviation type:
  1. 0x01: Left deviation
  2. 0x02: Right deviation
road_sign_t
Road sign type
  • 0x01: Speed limit sign
  • 0x02: Height limit sign
  • 0x03: Weight limit sign
road_sign_d
TKStar
tkstar_base_st_area_code - Area code
tkstar_base_st_contry_code - Country code
tkstar_base_st_oper_num - Operator number
tkstar_base_st_towe_num - Tower number
tkstar_bat_charge - Battery charge percentage
tkstar_displacement_alarm - Extended alarm status
tkstar_iccid - SIM card ICCID number
tkstar_motion_status - (00)Still to motion; (01)Move to rest;
tkstar_pos_status - (00) Not positioned; (10) WiFi positioning; (01) GPS
positioning;
tkstar_term_built_in_volt - the internal voltage value
tkstar_vibration_alarm
iccid
SIM Card ICCID Number
extended_alarm_status
State [31~0]
bit 0: 1 Battery switch - off ; 0Battery switch - on ( battery )
bit 1: 1 Terminal is in normal state; 0 Terminal sleep state (sleep)
bit 2: 1 Normal; 0 Driving without credit card
bit 3: 1 Normal; 0 Speeding during the time period
bit 4: 1 Normal; 0 Collision Alarm
bit 5: 1 The evaluator is connected normally, 0 Evaluator access abnormality
bit 6: 1 Top cover closed; 0 Top cover not closed
bit 7: 1 Carriage not raised; 0 car Carriage lifting
bit 8: 1 Normal ; 0 Rapid acceleration alarm Note : The sign remains until the alarm condition is lifted.
bit 9: 1 Normal ; 0 Sudden deceleration alarm Note : The sign remains until the alarm condition is removed
bit 10: 1 Acceleration sensor is normal ; 0 Acceleration sensor abnormality
bit 11: 1 Normal ; 0 Illegal displacement alarm
bit 12: 1 Normal; 0 Illegal removal
bit 13: 1 : Normal 0: High temperature alarm
bit 14: 1 : Normal 0: Low temperature alarm
bit 15: 1 : Normal 0: Vibration alarm
bit 16: 1 : Normal 0: Cut alarm ( ultrasonic oil sensor)
bit 17: 1 : Normal 0: Power failure alarm ( relieved after receiving response)
bit 18: 1 : Normal 0: Idle alarm ( relieved after receiving response)
bit 19: 1 led Advertising screen access is normal , 0 led The advertising screen is faulty or not connected
bit 20: 1 The meter is connected normally, 0The meter is faulty or not connected
bit 21: 1The multi-function screen is connected normally , 0The multi-function screen is faulty or not connected
bit 22: 1 normal , 0Lack of material alarm
bit 23 : 1 Normal, 0 Abnormal VisionFrequency connection status
bit 24: 1 ACC normal , 0 ACC Disconnection alarm
bit 25: 1 : Normal 0: Sharp turn Call the police
bit 26: 1 : Normal0 : ACC Alarm prompt from off to o
bit 27: 1 : Main power switch is normal 0: Main power switch is abnormal
bit 28: 1 : Burner switch is normal 0: Burner switch is abnormal
bit 29:1 : Vibration alarm switch off 0: Vibration alarm switch on
bit 30 : 1 : Normal 0 : Detected a fake base station
extended_alarm_status_2
State [0~31] The default is 0xFFFFFFFF
Bit 0: 1 : Software Off - Off 0 : Soft Switch - On
Bit 1: 1 : Waybill mode - Off 0 : Waybill mode - On
Bit 2: 1 : Not charging 0 :Charging
Bit 3/ Bit 4 Positioning status
Bit 3 = 0 Bit 4=0 Not positioned ( indicates GPS and WIFI Not positioned )
Bit 3 = 1 Bit 4=0 GPS Position
Bit 3 = 0 Bit 4=1 WIFI position
Bit 5: 1 : Not unloaded 0 : Unloaded
Bit 6: 1 : Normal 0 :Vibration alarm
Bit 7: 1 : Normal 0 : Collision alarm
Bit 8: 1 : Disarm 0 :Arm
Bit 9: 1 : Still 0 :Moving
Bit 10/ Bit 11 Operating mode
Bit 10= 1 Bit 11= 1 Normal working mode Bit 10=0 Bit 1 1= 1 Deep power saving model
Bit 10= 1 Bit 11=0 Intelligent power saving mode
Bit 12: 1 : Not forced open GPS 0: Force on GPS (Forced GPS Indicates that it can be found The wifi signal must also be turned on GPS Power, power off or set to shut down and force open GPS
Bit 13: 1 : Wired mode 0 :Wireless mode
Bit 14: 0 : See the light 1 : No light seen
Bit 15: 1 :G- Sensor Mode 0 : Non G- Sensor model
Bit 16 : 1 : Infrared normal 0 : Infrared abnormal
Bit 17: 1 : Normal pressure 0: High pressure alarm
Bit 18: 1 : Recorder normal 0: Recorder abnormal GH 01
Bit 19/ Bit 20 Positioning mode
Bit 19=0 Bit 20= 1 means single Beidou positioning
Bit 19= 1 Bit 20=0 means single GPS position
Bit 19=0 Bit 20=0 means dual-mode positioning
Bit 21=0 Speeding reminder Bit 21= 1 Oil circuit function
Bit 22 = 0 Oil circuit disconnect Bit 22= 1. Oil circuit is normal
Bit 23 = 0 Traffic restriction alarm Bit 23= 1Normal
Bit 24=0 Undervoltage protection status Bit 24= 1 normal status
Bit 25=0 low power mode Bit 25= 1 Not low power mode
Bit 26 = 0 Client Mode Bit 26= 1 BSJ model
Bit 27 = 0 Left turn speeding alarm Bit 27= 1 normal
Bit 28 = 0 Right turn speeding alarm Bit 28= 1 normal
Bit 29 = 0 Infrared 1 Trigger Bit 29=1 infrared 1 Not triggered
Bit 30 = 0 Infrared 2 Trigger Bit 30=1 infrared 2 Not triggered
Bit 31 = 0 Infrared 3 Trigger Bit 31=1 infrared 3 Not triggered
pwr_ext
External voltage
V
pwr_int
Internal power
V
tkstar_light_alarm
0 see light
1 see no light
Grow your business with us
