S2 Series
Number of units
0
Online
Total
Features S2 Series:
  • 4G/LTE
  • ADAS
  • Blackbox
  • DMS
  • Sending data to multiple servers
Supported in Wialon:
  • Event video
  • Remote management via GPRS
  • Live stream
  • Manual video saving
  • Playback
  • Communication via TCP
The following data should also be added to S2 Series unit properties section of Wialon GPS tracking software :
Device type: S2 Series
Unique ID: custom
Specify the following parameters in configuration software or configuration S2 Series for use in Wialon Hosting :
Server port: 22877
3 units of S2 Series device type are connected to Wialon Data Center. This represents 0% of all Video monitoring connected.
param_id_#
Parameter value
event_#
Event
alarm_flag
Alarm flag (Bits1-32):
Bit2: 1: Over speed alarm
Bit4: 1: Risk warning
Bit12: 1: Camera malfunction
Bit14: 1: Over speed warning
Bit16-Bit18: Reserve
Bit20: 1: Timeout parking
Bit24: 1: Off track alarm
Bit30: 1: Collision warning
Bit31: 1: Rollover warning
state_flag
Status (Bits 1-32):
Bit1: 0: ACC off; 1: ACC on
Bit7-Bit8: Reserve
Bit23-32: Reserve
odometer
Odometer
fuel_volume
Fuel volume
speed_drvng_rec
Speed driving rec
alarm_event_id
Alarm event ID
overspeed_alarm
Overspeed alarm
position_type
Position type
section_id
Section ID
route_alarm
Route alarm
direction
Direction
driving_time_alarm
Driving time alarm
driving_time
Driving time
driving_results
Driving results
video_alarm
Video related alarm
Bit 1 Video signal loss alarm
Bit 5 Over passengers alarm
Bit 8-32 Reserved
video_signal_loss_alarm
video_signal_block_alarm
memory_fault_alarm
abnormal_driving_alarm
Bit1:fatigue;
Bit2:call;
Bit3:smoking;
veh_signal_status
Veh. signal status
user_msg
User mesage
veh_stat
info_id
Additional information ID
  4. 0x14 - Video-related alarm
  7. 0x17 - Memory fault alarm
alm_time
Alarm time threshold
sec
alm_thre1
Warning threshold 1
alm_thre2
Warning threshold 2
workstate
Workstate,
0x01: normal work
0x02: standby mode
0x03: Upgrade maintenance
0x04: Device is abnormal
0x10: Disconnect
alarm_status
Alarm status, bits(1-32)
bit1: cameraabnormal
bit2: Main memory exception
bit5: abnormal speaker
bit6: Abnormal battery
bit7~bit10:reserved
bit13~bit32:reserved
alm_lvl
Warning level:
  • 0x01: Level 1 warning
  • 0x02: Level 2 warning
alm_id
sign_stat
Sign status.
  • 0x00: Not available
  • 0x01: Start sign
  • 0x02: End sign
veh_ah_spd
km/h
veh_ah_dst
dev_type
Deviation type:
  1. 0x01: Left deviation
  2. 0x02: Right deviation
road_sign_t
Road sign type
  • 0x01: Speed limit sign
  • 0x02: Height limit sign
  • 0x03: Weight limit sign
road_sign_d
iccid
SIM Card ICCID Number
pwr_ext
External voltage
V
pwr_int
Internal power
V
tkstar_light_alarm
0 see light
1 see no light
result
Terminal universal reply:
0: success/confirmation;
1: Failure;
2: Wrong message;
3: No support;
4: alarm confirmation and processing.
Grow your business with us
