SV-D14
Number of units
31
Online
92
Total
Features SV-D14:
  • 4G/LTE
  • Blackbox
  • BLE enabled
  • Voice calls
Supported in Wialon:
  • Accelerometer
  • Event video
  • Live stream
  • Manual video saving
  • Playback
  • Communication via TCP
The following data should also be added to SV-D14 unit properties section of Wialon GPS tracking software :
Device type: SV-D14
Unique ID: custom
Specify the following parameters in configuration software or configuration SV-D14 for use in Wialon Hosting :
Server port: 22918
92 units of SV-D14 device type are connected to Wialon Data Center. This represents 0.15% of all Video monitoring connected.
param_id_#
Parameter value
event_#
Event
alarm_flag
Alarm flag (Bits1-32):
Bit2: 1: Over speed alarm
Bit4: 1: Risk warning
Bit12: 1: Camera malfunction
Bit14: 1: Over speed warning
Bit16-Bit18: Reserve
Bit20: 1: Timeout parking
Bit24: 1: Off track alarm
Bit30: 1: Collision warning
Bit31: 1: Rollover warning
state_flag
Status (Bits 1-32):
Bit1: 0: ACC off; 1: ACC on
Bit7-Bit8: Reserve
Bit23-32: Reserve
odometer
Odometer
fuel_volume
Fuel volume
speed_drvng_rec
Speed driving rec
alarm_event_id
Alarm event ID
overspeed_alarm
Overspeed alarm
position_type
Position type
section_id
Section ID
route_alarm
Route alarm
direction
Direction
driving_time_alarm
Driving time alarm
driving_time
Driving time
driving_results
Driving results
video_alarm
Video related alarm
Bit 1 Video signal loss alarm
Bit 5 Over passengers alarm
Bit 8-32 Reserved
video_signal_loss_alarm
video_signal_block_alarm
memory_fault_alarm
abnormal_driving_alarm
Bit1:fatigue;
Bit2:call;
Bit3:smoking;
veh_signal_status
Veh. signal status
user_msg
User mesage
veh_stat
info_id
Additional information ID
  4. 0x14 - Video-related alarm
  7. 0x17 - Memory fault alarm
alm_time
Alarm time threshold
sec
alm_thre1
Warning threshold 1
alm_thre2
Warning threshold 2
workstate
Workstate,
0x01: normal work
0x02: standby mode
0x03: Upgrade maintenance
0x04: Device is abnormal
0x10: Disconnect
alarm_status
Alarm status, bits(1-32)
bit1: cameraabnormal
bit2: Main memory exception
bit5: abnormal speaker
bit6: Abnormal battery
bit7~bit10:reserved
bit13~bit32:reserved
alm_lvl
Warning level:
  • 0x01: Level 1 warning
  • 0x02: Level 2 warning
alm_id
sign_stat
Sign status.
  • 0x00: Not available
  • 0x01: Start sign
  • 0x02: End sign
veh_ah_spd
km/h
veh_ah_dst
dev_type
Deviation type:
  1. 0x01: Left deviation
  2. 0x02: Right deviation
road_sign_t
Road sign type
  • 0x01: Speed limit sign
  • 0x02: Height limit sign
  • 0x03: Weight limit sign
road_sign_d
iccid
SIM Card ICCID Number
pwr_ext
External voltage
V
pwr_int
Internal power
V
tkstar_light_alarm
0 see light
1 see no light
result
Terminal universal reply:
0: success/confirmation;
1: Failure;
2: Wrong message;
3: No support;
4: alarm confirmation and processing.
alm_type
Note: parameters are registered in DEC in Wialon, so you need to convert value from this table from HEX to DEC before checking values in Wialon. For example, to check information about the 0x11: Driver change event with info_id = 0x64, you need to use values alm_type=17, info_id=101. You can try to filter Messages by following parameters or use them in sensors.
Alarm type if info_id = 100 (0x64):
DEC (HEX): Definition
1 (0x01): Forward collision warning
2 (0x02): Lane departure warning
3 (0x03): Overly close vehicle warning
4 (0x04): Pedestrian collision warning
5 (0x05): Frequent lane change warning
6 (0x06): Exceeding road sign warning
7 (0x07): Obstacle warning
8 (0x08): Driver Assist Function Failure Warning
9~15 (0x09~0x0F): User customization
16 (0x10): Road sign identification event
17 (0x11): Active capture event
18~255 (0x12~0xFF): User customization
Alarm type if info_id = 101 (0x65):
1 (0x01): Fatigue driving warning
2 (0x02): Calling on hand-held mobile phone warning.
3 (0x03): Smoking warning
4 (0x04): Long time without looking ahead warning.
5 (0x05): No driver detected warning.
6 (0x06): Both hands leave steering wheel warning
7 (0x07): Driver behavior monitoring function failure warning
8~15 (0x08~0x0F): User customization
16 (0x10): Automatic capture event
17 (0x11): Driver change event
Alarm type if info_id = 112 (0x70):
DEC(HEX): Definition
1 (0x01): Sharp acceleration warning
2 (0x02): Sharp deceleration warning
3 (0x03): Sharp turn warning
4 (0x04): Idle speed warning
5 (0x05): Abnormal flameout warning
6 (0x06): Neutral taxi warning
7 (0x07): Engine overrunning warning
Grow your business with us
