Lytx Drivecam
Lytx Drivecam
Manufacturer: Lytx
Number of units
0
Online
Total
The following data should also be added to Lytx Drivecam unit properties section of Wialon GPS tracking software :
Device type: Lytx Drivecam
Unique ID: custom
4 units of Lytx Drivecam device type are connected to Wialon Data Center. This represents 0.01% of all Video monitoring connected.
vehicle_name
Name of the vehicle
string
trip_end
Timestamp in UTC when the trip ended
UTC datetime
trip_distance_km
Distance traveled by the vehicle from the start position to the end position of the trip
km
trip_max_speed_kph
Maximum speed reached by the vehicle during a speeding violation
km/h
event_id
Unique id for the event
event_customer_id
Unique id for the event within the customer's data
event_trigger_type
Event trigger types (click to see description):
1 = Manual,
2 = Erratic,
3 = Shock,
4 = Remote,
5 = Safety - Open,
6 = Safety - Close,
7 = Fail.
event_status Key into the GetEventStatuses lookup call identifying the event's current status (EventsInfo.EventStatusId, Lytx Events API). Values include New, Face-To-Face Coaching, Resolved, Self Coaching, FYI Notify, Internal Notify, Remote Coaching.
event_code First behavior id associated with the event, key into the GetBehaviors lookup call (EventsInfo.Behaviors[0].Behavior, Lytx Events API).
event_codes Full list of behavior ids currently associated with the event, joined by comma, each a key into the GetBehaviors lookup call (EventsInfo.Behaviors[*].Behavior, Lytx Events API).
event_trigger_subtype Event trigger subtype, derived from the Lytx Events API EventTypeId text descriptions (GetEventTypes). No distinct "subtype" field exists in the Lytx Events API docs; this parameter reuses the same EventTypeId enumeration as a textual sub-classification: 1=Manual, 2=Erratic, 3=Shock, 4=Remote, 5=Safety - Open, 6=Safety - Close, 7=Fail. (List may be incomplete - source XML example in the doc was truncated after ID 7; confirm full set via a live GetEventTypes call.)
vehicle_status Current operational status of the vehicle as reported by the Lytx DriveCam device (e.g. In Service, Out of Service, Spare).
last_communication Timestamp of the last successful communication/data exchange between the Lytx Event Recorder (ER) and the Lytx cloud platform. UTC datetime
hdop Horizontal Dilution of Precision (HDOP) value for the GPS fix at the time the point was captured, indicating GPS positional accuracy quality. Lower values indicate better satellite geometry/accuracy.
haccuracy Horizontal accuracy estimate of the GPS position fix at the time the point was captured. m
trip_start_address Reverse-geocoded street address of the trip's starting position.
trip_id Unique identifier assigned to the trip record by the Lytx platform.
license_plate License plate number of the vehicle associated with the trip or event. string
event_video_offset_ms Offset, in milliseconds, into the associated event video clip at which the triggering telemetry/behavior occurred. ms
More tehcnical information about the device you could find in the documentation.
Grow your business with us
