SmartWitness KP1
SmartWitness KP1
Discontinued
Number of units
0
Online
20
Total
Features SmartWitness KP1:
  • 3G
Supported in Wialon:
  • Camera connection
  • Remote management via GPRS
  • Driver identification
  • Digital sensors(RS232/RS485)
  • Alarm button
  • Communication via TCP
The following data should also be added to SmartWitness KP1 unit properties section of Wialon GPS tracking software :
Device type: SmartWitness KP1
Unique ID: DRID
Specify the following parameters in configuration software or configuration SmartWitness KP1 for use in Wialon Hosting :
Server port: 20910
20 units of SmartWitness KP1 device type are connected to Wialon Data Center. This represents 0.03% of all Video monitoring connected.
vehicle_id Vehicle Number
ID/avl_driver Driver ID from SD Card, RFID Card, etc.
phone_number Usim phone number
valid GPS validity. Valid: 1, Invalid: 0
pulse_speed Pulse Speed, km/h
rpm Revolutions per minutes
signal
Bitflag:
Bit4 - Engine(Ignition): 0(On), 1(Off)
Bit3 - Reverse status
Bit2 - Brake status
Bit1 - Right status
Bit0 - Left status
alarm_in Bitflag Alarm In status. AlarmIn8(bit7) - AlarmIn1(bit0)
alarm_out Bitflag Alarm Out status. AlarmOut2(bit1), AlarmOut1(bit0)
record 0: not recording, 1: recording
error_media
BitFlag:
Bit0 - error in SD1
Bit1 - error in SD2
Bit4 - error in HDD1
Bit5 - error in HDD2
cam_signal Bitflag camera signal valid. Cam8(bit7) ~ Cam1(bit0)
rec_model
Recorder Model:
1 - DVR 4CH/DVR 8CH
2 - KP1
rec_fw Recorder FW
rec_power_type
Recorder Power Type:
1 - DEVPOWER_CIGAR
2 - DEVPOWER_ADAPTER
3 - DEVPOWER_JUNCTIONBOX
4 - DEVPOWER_ADAPTER2 (INT1-S)
rec_cam Bitflag camera enable info. Cam8(bit7) - Cam1(bit0)
das_key DASKey
x_gsensor GSENSOR, X-axis (-2000 ~ 2000, mG) mG
y_gsensor GSENSOR, Y-axis (-2000 ~ 2000, mG) mG
z_gsensor GSENSOR, Z-axis (-2000 ~ 2000, mG) mG
event_type
Event Type Bit Flags:
Bit0 - DEVENT_MOTION
Bit1 - DEVENT_ALARMIN
Bit2 - DEVENT_SIGNAL
Bit3 - DEVENT_GS_TURN
Bit4 - DEVENT_GS_ACCEL
Bit5 - DEVENT_GS_BRAKE
Bit6 - DEVENT_GS_SHOCK
Bit7 - DEVENT_GS_ETC
Bit8 - DEVENT_SPEED
Bit9 - DEVENT_NVS
Bit10 - DEVENT_PBUTTON
Bit11 - DEVENT_PARKINGMODE
Bit12 - DEVENT_RPM
Bit13 - DEVENT_IDLING
Bit14 - DEVENT_SYSWARNING
Bit16 - DEVENT_GEOFENCE
Bit17 - DEVENT_SERVERFORCE
Bit28 - DEVENT_DEMO
motion_channel
Camera Number. BitFlags:
Bit0 - Camera 1
Bit1 - Camera 2
Bit2 - Camera 3
etc.
alarm_in_channel
Alarm In Number. BitFlags:
Bit0 - Alarm 1
Bit1 - Alarm 2
Bit2 - Alarm 3
etc.
signal_channel
Signal Number. BitFlags:
Bit0 - Signal 1
Bit1 - Signal 2
Bit2 - Signal 3
etc.
nvs_channel
Bit0 - Camera 1
Bit1 - Camera 2
Bit2 - Camera 3
etc.
How to set up KP1 in Wialon
Allows for immediate event-based data transfer. Video file (up to 20 sec) request from the device internal storage is also available.
Grow your business with us
