Xirgo FMS500 Light
Xirgo FMS500 Light
Manufacturer: Xirgo Technologies
Number of units
696
Online
1313
Total
Features Xirgo FMS500 Light:
  • Blackbox
  • GLONASS support
  • Built-in odometer
Supported in Wialon:
  • Accelerometer
  • ADC sensors
  • ECO driving
  • Remote management via GPRS
  • Driver identification
  • Digital sensors
  • LBS
  • Remote management via SMS
  • Modification of the "speed" parameter
  • Communication via TCP
  • Communication via UDP
The following data should also be added to Xirgo FMS500 Light unit properties section of Wialon GPS tracking software :
Device type: Xirgo FMS500 Light
Unique ID: imei
Specify the following parameters in configuration software or configuration Xirgo FMS500 Light for use in Wialon Hosting :
Server port: 21984
1313 units of Xirgo FMS500 Light device type are connected to Wialon Data Center. This represents 0.06% of all AVL Hardware connected.
acc_pedal J1939 Acceleration Pedal Position %
axle_location Axel Location
axleN Axel weight kg
axle_wgt Axel Weight kg
c1-4 Counter Frequency Hz
can_engine_hrs J1939 Total Engine Hours h
can_fls J1939 Fuel Level L
can_mileage J1939 Total Vehicle Distance m
can_taho J1939 Engine Speed rpm
cell_id Cell ID
dallas_humidity Wire Humidity %
dallas_id_end Wire ID
dallas_temp Wire Temperature °C
engine_temp J1939 Engine Coolant Temperature °C
fN Event Code of Function N
fuel_con_ins Instant fuel consumption calculated L
fuel_lvl2 J1939 Fuel Level2 %
fw_version FW Version
gsm_lvl GSM Signal Level dBm
hdop HDOP (Horizontal Dilution Of Precision)
J1708_eng_hrs J1708 Total Engine Hours h
J1708_fl_lvl J1708 Total Fuel Level %
J1708_fl_used J1708 Total Fuel Used L
j1939_adblue J1939 Diesel Exhaust Fluid Tank 1 Level L or % (depends on tank size)
j1939_air_temp J1939 Ambient Air Temperature °C
j1939_driver_id J1939 Driver Id
j1939_dtc1-10 J1939 DTC1-10
j1939_eng_load J1939 Engine Load %
j1939_fl_con J1939 High Resolution Fuel Consumption
j1939_flfmseco J1939 Instantaneous Fuel Economy km/L
j1939_fuel_rate J1939 Fuel Rate L/h
j1939_mil_stat J1939 MIL Status
j1939_motion TCO1 Vehicle Motion
j1979_air_temp J1979 Intake Air Temperature °C
j1979_dtc1-10 J1979 DTC1-10
j1979_eng_load J1979 Calculated Engine Load Value
j1979_eng_temp J1979 Engine Coolant Temperature °C
j1979_fl_lvl J1979 Fuel Level Input %
j1979_fl_pres J1979 Fuel Pressure kPa
j1979_flrate J1979 Engine Fuel Rate L/h
j1979_hbrbatlif J1979 Hybrid Battery Pack Remaining Life %
j1979_lgfltrim1 J1979 Long Term Fuel Trim (Bank 1) %
j1979_lgfltrim2 J1979 Long Term Fuel Trim (Bank 2) %
j1979_maf J1979 Air Flow Rate from MAF Sensor g/s
j1979_map J1979 Intake Manifold Absolute Pressure kPa
j1979_mil_stat J1979 Lamp (MIL) Status
j1979_rail_pres J1979 Fuel Rail Pressure kPa
j1979_rpm J1979 Engine RPM rpm
j1979_shfltrim1 J1979 Short Term Fuel Trim (Bank 1) %
j1979_shfltrim2 J1979 Short Term Fuel Trim (Bank 2) %
j1979_speed J1979 Vehicle Speed km/h
j1979_tps J1979 Throttle Position %
jamm Jamming Alarm
lac Location Area Code
lls_lvl_addN LLS Fuel Level number N
lls_temp_addN LLS Fuel Temperature number N
lvl1 Filtered ADC 1
lvl2 Filtered ADC 2
me_time_indicator ME5 Time indicator
me_time_sound_type ME5 Sound type
me_time_zero_speed ME5 Zero Speed
me_headway_measure ME5 Headway measure
me_error_code ME5 Error code
me_can_mess700_b4
ME5 parameters:
1 bit - LDW OFF
2 bit - Left LDW ON
3 bit - Right LDW ON
4 bit - FCW on
7 bit - Maintence
8 bit - Failsafe
me_can_mess700_b5
ME5 parameters:
2 bit - Peds FCW
3 bit - Peds DZ
6 bit - Tamper Alert
8 bit - TSR enabled
me_tsr_warn_level ME5 TSR Warning Level
me_hw_repeat_enabled ME5 HW repeatable enabled
me_hw_warn_level ME5 Headway Warning Level
me_can_mess760_b0
ME5 parameters:
1 bit - Brakes
2 bit - Left Signal
3 bit - Right Signal
4 bit - Wipers
5 bit - Low Beam
6 bit - High Beam
me_can_mess760_b1
ME5 parameters:
4 bit - Wipers Available
5 bit - Low Beam Available
6 bit - High Beam Available
8 bit - Speed Available
me_speed ME5 Speed km/h
mcc Mobile Country Code
mnc Mobile Network Code
name Image Name
odo Odometer m
srv_dist J1939 Service Distance km
ta Timing Advance
tco1_dir TCO1 Direction Indicator
tco1_drv1_crd TCO1 Driver 2 Card
tco1_drv1_time TCO1 Driver 1 Time Rel States
tco1_drv1_work TCO1 Driver 1 Working State
tco1_drv2_crd TCO1 Driver 2 Card
tco1_drv2_time TCO1 Driver 2 Time Rel States
tco1_drv2_work TCO1 Driver 2 Working State
tco1_event TCO1 System Event
tco1_handl TCO1 Handling Information
tco1_overspeed TCO1 Vehicle Overspeed
tco1_perf TCO1 Tachgraph Performance
tco1_speed TCO1 Vehicle Speed
tire_location Tire Location
total_fuel J1939 Total Fuel Used L
wheel_speed J1939 Wheel Speed km/h
wie Wiegand 26 Identification Code
Grow your business with us
