Hero-ME32-06
Hero-ME32-06
Manufacturer: Howen Technologies
Number of units
0
Online
Total
Features Hero-ME32-06:
  • 4G/LTE
  • Blackbox
  • Sending data to multiple servers
Supported in Wialon:
  • ADC sensors
  • CAN-bus support
  • Event video
  • Digital sensors(RS232/RS485)
  • Live stream
  • Manual video saving
  • Playback
  • Communication via TCP
The following data should also be added to Hero-ME32-06 unit properties section of Wialon GPS tracking software :
Device type: Hero-ME32-06
Unique ID: custom
Specify the following parameters in configuration software or configuration Hero-ME32-06 for use in Wialon Hosting :
Server port: 22995
5 units of Hero-ME32-06 device type are connected to Wialon Data Center. This represents 0.01% of all Video monitoring connected.
va People counting, current onbus people number byte is valid or not (device calculated), 0-invalid, 1-valid
event_type Event type code: 0-unknown, 1-video lost, 2-motion detection, 3-video blind, 4-input trigger, 5-emergency alarm, 6-low speed alarm, 7-over speed alarm, 8-low temperature alarm, 9-high temperature alarm, 10-humidity alarm, 11-parking over time, 12-acceleration alarm, 13-GEO fencing, 14-electronic route, 15-abnormal openclose the door, 16-storage abnormal, 17-fatigue driving, 18-fuel consumption abnormal, 19-illegal ACC, 20-GPS module abnormal, 21-front panel open, 22-Swipe card, 23-IBUTTON, 24-Harsh acceleration, 25-Harsh braking, 26-Low speed warning, 27-High speed warning, 28-Voltage alarm, 29-People counting, 30-ADAS alarm, 31-"Acc on" (report once at boot), 32-Idle, 33-Gps antenna break, 34-Gps antenna short, 35-IO output, 36-CAN Bus connection abnormal, 37-Towing, 38-Free wheeling, 39-RPM exceeds, 40-Vehicle Move, 41-Trip start, 42-In trip, 43-Trip ends, 44-GPS location recover, 45-Video abnormal, 768-Trip notification, 769-Upgrade notification
I/O 1-Close, 2-Emergency, 3-Front door, 4-Middle door, 5-Back door, 6-Dipped headlight (near light), 7-High beam (far light), 10-Right turn light, 11-Left turn light, 12-Brake, 13-Back a vehicle, 14-(Reserved), 15-The front door close, 16-The middle door close, 17-The back door close, 18-Intercom, 19-Lifting, 20-Seal, 21-Loading, 23-Customer define, 24-Safe to load, 32-Ibutton2
in_veh_temp Temperature in vehicle
video_loss bit0 - channel 1 video loss indicator (0: no video loss, 1: video loss); bit1 - channel 2; bit2 - channel 3; etc.
cnt_lat People counting latitude
geofence_threshold The speed value alarm value. Valid when geofence_status = 2 or 4 Km/h
alarm_et Event end time
mb mobile phone number
position_accuracy Positioning accuracy m
gsensor_impact GSensor impact g
swipe_card_rvrsd Card number, etc.
driver_data Driver info
at Access network. 1-Ethernet 2-WIFI 3-2G
ssid Wi-Fi ssid
fn file path. For example, "/mnt/sd1/xxxx.264"
alc_concentr Alcohol concentration mg/100ml
cur_mileage Current day mileage meter
video_type video type: video/mp4
wifi_gateway Wi-Fi gateway address
total_mileage Total mileage meter
location_type Location type. 0—location invalid; 1--GPS; 2--BD; 3--Glonass; 4--AGPS; 5--base station location; 6 - WIFI
obd_air_press_N Intake pressure in Kpa
wifi_module WIFI module. 0--unknown 1--normal 2--abnormal 3—not exist
wifi_net_addr Wi-Fi network address
dt Device Type
mt Media Type. 1-live view 2-playback 3-audio 4-file transmission 5-serial transmission
dw0 The number of offbus people, <0 means invalid
sc_ht Swipe card information. History: 1 — Historical data; 2 — Real time data; Else — invalid
trigg_threshold Trigger threshold mg/100ml
swipe_card Swipe card number
y_accel GSensor acceleration, Y axis g
geofence_status Values description: 0-enter, 1-exit, 2-over-speed alarm, 3-over-speed warning, 4-low speed alarm, 5-low speed warning, 6-forbidden parking engine star, 7-forbidden parking engine off, 8-overtime stay in geofence, 9-Pre-entry, 10-Pre-exit
max Acceleration alarm, Maximum value during the alarm
obd_i_fuel_cons_N Instant fuel consumption in L/km
obd_rpm_N Engine speed in rpm
alarm_inputs Alarm inputs triggered: bit0 - input 1; bit1 - input 2; etc.
out_veh_temp Temperature outside of vehicle
alarm_st Event start time
ft file type: 0-unknown, 1-general recording, 2-alarm recording, 3-general snapshot file, 4-alarm snapshot file, 5-upgrade file, 6-log file, 7-Configuration file, 8-Black box file, 9-Visible alarm video/snapshot
dw1 The number of offbus people, <0 means invalid
obd_int_temp_N Intake air temperature
obd_cool_temp_N Coolant temperature
in_veh_hum Humidity in vehicle
ver Current version of device
cnt_tm People counting time
motor_temp Motor temperature
obd_thr_pos_N Throttle position in %
voltage_N Vehicle voltage. Double value, in V.
obd_rem_oil_N Remaining oil in %
out_veh_hum Humidity outside of vehicle
cur Acceleration alarm, Current value when reporting
wifi_subnet Wi-Fi subnet mask
ibutN iButton code. N - iButton number
err Error code: 0 Success, 1 Duplicated ID, 2 invalid parameter, 3 invalid command, 4 device busy, 5 connection lost, 6 related file not exist, 7 disk not exist, 8 follow up data, 9 file search finish, 10 Device is not authorized, 255 Unknown error
min Acceleration alarm, Minimum value in a period
hdN_capacity Hard disk N (disk index) balance capacity Mega Bytes
filetype 0-unknown, 1-general recording, 2-alarm recording, 3-general snapshot file, 4-alarm snapshot file, 5-upgrade file, 6-log file, 7-Configuration file, 8-Black box file, 9-Visible alarm video/snapshot
drid Driver ID
pat People counting. 0-real time; 1-stored and forward (data was resent after network works)
cnt_lon People counting longitude
pre Acceleration alarm, The value of one second before
x_accel GSensor acceleration, X axis g
ts Transmission Status: 1-Start, 0-End
mob_signal Mobile signal intensity
video_uri video URI
adas_alarm_type ADAS: 1-Forward collision alarm, 2-Lane departure warning, 3-Car distance too near, 4-Pedestrian collision alarm, 5-Frequent lane change alarm, 6-Road sign violate alarm, 7-Harsh Acceleration, 8-Harsh Breaking, 9-Safety Distance, 16-Traffic Sign Recognition, 17-FCW: Forward collision warning, 18-HMW: Headway monitoring warning, 19-Left Lane departure warning, 20-Right Lane departure warning, 21-VB Forward Collision Warning. DMS: 33-Fatigue driving alarm, 34-Phone call alarm, 35-Smoking alarm, 36-Distracted driving alarm, 37-Driver abnormal alarm, 49-Driver change event, 65-Eye closed, 66-Yawning, 67-Camera cover, 68-Distracted Driving, 69-Seat belt not fastened, 70-No driver, 72-Driver shift, 73-Driver back, 80-Infrared sunglasses, 81-Driver ID identified successfully, 82-Driver ID identified failed, 83-No Driver face detected, 85-Mask not worn
gsensor_tilt GSensor tilt g
mob_net_type Mobile network type: 0 - unknown; 3 - 2G; 4 - 3G; 5 - 4G; 6 - 5G
device_temp Device temperature
ap The hotspot when MDVR connects to the sever in WiFi mode.
modem_status Satellite Modem Status: 0-Working normal, 1-Module normal, satellite communication abnormal, 2-Module abnormal
status1 bit0 - ACC (0-invalid,1-valid); bit1-break (0-invalid, 1-valid); bit2 - turn left (0-invalid,1-valid); bit3 - turn right (0-invaid,1-valid); bit4 - forward (0-invalid, 1-valid); bit5 - backword (0-invalid,1-valid); bit6 - left front door (0-Close,1-Open); bit7 - right front door (0-close,1-Open)
alarms Alarm status: bit0—video loss; bit1—motion detection; bit2—video blind; bit3—alarm input trigger; bit4—over speed alarm; bit5—low speed alarm; bit6—emergency alarm; bit7—over time stop; bit8—vibration alarm; bit9—out of GEO fencing alarm; bit10—enter GEO fencing alarm; bit11—exist line alarm; bit12—enter line alarm; bit13—fuel level alarm
hdN_status Hard disk N (disk index) status: 0 - unknown; 1 - recording; 2 - idle; 3 - abnormal; 4 - full
gsensor_status GSensor status. 0--unknown 1--normal 2--abnormal 3—not exist
bluetooth_data Bluetooth status: 0-not connected, 1-connected
balance_fuel Balance fuel
sc_up Swipe card information. Onboard/offboard: 1 — Onboard (check in); 2 — Off board (check out); Else — invalid
device_tm Event device time
up0 The number of onbus people, <0 means invalid
hdN_size Hard disk N (disk index) size Mega Bytes
text information message
up1 The number of onbus people, <0 means invalid
fuel_cons Fuel consumption
ch Media channel. starting from 1, 0 means no need for the channel.
wifi_signal Wi-Fi signal intensity
recording_status Bit0 - channel 1 is recording; Bit1 - channel 2 is recording; Bit2 - channel 3 is recording; Bit3 - channel 4 is recording; Bit4 - channel 5 is recording; etc.
dt_ Acceleration alarm, direction: 1-X direction, 2-Y direction, 3-Z direction, 4-impact, 5-tilt, 6-turn
gps_module GPS location module. 0--unknown 1--normal 2--abnormal 3—not exist
status2 bit0 - left mid door (0-close, 1-open); bit1 - right mid door(0-close, 1-open); bit2 - left back door(0-close, 1-open); bit3 - right back door(0-close, 1-open)
video_blind Video blind: bit0 - channel 1; bit1 - channel 2; etc.
z_accel GSensor acceleration, Z axis g
tt Acceleration alarm, time threshold
obd_t_mil_N Accumulated mileage in km.
vt Acceleration alarm, trigger threshold
drname Driver name
motion Motion detection: bit0 - channel 1; bit1 - channel 2; etc.
obd_t_fuel_cons_N Cumulative fuel consumption in L.
filename Corresponding file name of recording file. It is usually used in alarm recording playback, and start time/end time is invalid in this mode.
obd_eng_load_N Engine load in %
mobile_net Mobile network. 0--unknown 1--normal 2--abnormal 3—not exist
alarm_ec Event type code: 0-unknown, 1-video lost, 2-motion detection, 3-video blind, 4-input trigger, 5-emergency alarm, 6-low speed alarm, 7-over speed alarm, 8-low temperature alarm, 9-high temperature alarm, 10-humidity alarm, 11-parking over time, 12-acceleration alarm, 13-GEO fencing, 14-electronic route, 15-abnormal openclose the door, 16-storage abnormal, 17-fatigue driving, 18-fuel consumption abnormal, 19-illegal ACC, 20-GPS module abnormal, 21-front panel open, 22-Swipe card, 23-IBUTTON, 24-Harsh acceleration, 25-Harsh braking, 26-Low speed warning, 27-High speed warning, 28-Voltage alarm, 29-People counting, 30-ADAS alarm, 31-"Acc on" (report once at boot), 32-Idle, 33-Gps antenna break, 34-Gps antenna short, 35-IO output, 36-CAN Bus connection abnormal, 37-Towing, 38-Free wheeling, 39-RPM exceeds, 40-Vehicle Move, 41-Trip start, 42-In trip, 43-Trip ends, 44-GPS location recover, 45-Video abnormal, 768-Trip notification, 769-Upgrade notification, 1280-Alarm file, 281-Timer Snapshot, 1282-Alarm file (in visible partition), 1283-ftp file upload notification
obd_speed_N speed, needs *100 for km/h
avg Acceleration alarm, Average value in a period
obd_pwr_N Vehicle voltage in V
obd_air_flow_N Intake air flow in G/s
6 ch all- in-one AI SSD MDVR, with compact design, IP69K water resistance performance, accurate
AI and rich interfaces. Designed for commercial vehicles like mining, oil & gas, etc.
Dimensions: W*D*H: 153* 154* 37 mm
Net weight: 1.25 kg
IP protection rating: IP69K
Working voltage: 9-36V DC
SIM Card slot:
1 x nano SIM card slot, eSIM (optional)
HDD/SSD: 1 x SSD slot, support 7/9/15mm 2.5inch SSD, max. 4TB
SD/TF card: 2 x TF card slots, max. 1TB each
Grow your business with us
