Gosafe G737
Gosafe G737
Manufacturer: Gosafe
Number of units
0
Online
Total
Features Gosafe G737:
  • Blackbox
  • Watch (bracelet)
Supported in Wialon:
  • Remote management via GPRS
  • SMS sending of data
  • Remote management via SMS
  • Communication via TCP
  • Communication via UDP
The following data should also be added to Gosafe G737 unit properties section of Wialon GPS tracking software :
Device type: Gosafe G737
Unique ID: serial
Specify the following parameters in configuration software or configuration Gosafe G737 for use in Wialon Hosting :
Server port: 20816
4 units of Gosafe G737 device type are connected to Wialon Data Center. This represents 0.02% of all Personal trackers connected.
bat_volt Device voltage V
cidN The identifier of GSM base station N
device_status Device status. Each bit represents one kind of event
dtt_event_status DTT data event status
event_id Event ID
event_status Event status identifier
geo_fence Geofence number that is triggered
geo_fenceM_N Number M to N Geofences status. Each bit represents each Geofence, bit 0 to bit N-M+1 represents Geofence M to Geofence N. 0 - outside Geofence or there is no Geofence assigned to device, 1 - inside Geofence
geo_local_tm Local time when Geofence event is triggered
geo_speed Speed when Geofence event is triggered km/h
geo_status Bit field. Bit0: 1 - over speed, 0 - speed is normal. Bit1: 1 - inside Geofence, 0 - outside Geofence
gps_fix GPS fix. 1 - fixed, 0 - not fixed
gsm_level Signal strength, range is 0 to 5
lacN The zone code of GSM base station N
mccN Mobile country code (base station N)
mncN Mobile network code (base station N)
pwr_int Backup battery voltage Volt
reg_status GSM registration status
rssiN Signal strength (base station N) dBm
tagN Tag ID of tag N
T_tag_entering ID of the tag that triggered TAG entering event. T - tag type (h - home tag, p - prison tag)
T_tag_leaving ID of the tag that triggered TAG leaving event. T - tag type (h - home tag, p - prison tag)
fw Firmware version
hw Hardware version
dev_name Device name
hdop
Horizontal Dilution of Precision
Grow your business with us
