Topflytech TLW2-12B
Number of units
1653
Online
8195
Total
Features Topflytech TLW2-12B:
  • Blackbox
  • BLE enabled
The following data should also be added to Topflytech TLW2-12B unit properties section of Wialon GPS tracking software :
Device type: Topflytech TLW2-12B
Unique ID: custom
Specify the following parameters in configuration software or configuration Topflytech TLW2-12B for use in Wialon Hosting :
Server port: 22095
8195 units of Topflytech TLW2-12B device type are connected to Wialon Data Center. This represents 5% of all Asset trackers connected.
mcc
Mobile country code
mnc
Mobile network code
lac
Location Area Code
cell_id
Mobile cell ID
mcu_model
MCU model
mcu_fw_ver
MCU firmware version
modem_ver
Modem version
modem_app
Modem app version
hw_ver
Hardware version
gsm
The GSM signal strength level
acc_on
ACC ON upload interval
s
acc_off
ACC OFF upload interval
s
speed_alarm
Speed alarm value
km/h or mile/h
angle
Angle
degree
distance
Distance compensation
m
gps_data
GPS data status
gsensor
Gsensor manager status
relay
Relay status
km/h
drag_alarm
Drag alarm setting
m
alarm
Alarm data
mileage
Mileage
m
pwr_int
Ineer battery voltage
pwr_ext
External power supply voltage
V
drv_beh_gps
Driver Behavior via GPS:
00 - means Δhb;
01 - means Δha;
02 -means Δmb;
03-means Δma;
04-means Δlb;
05-means Δla.
drv_beh_acc
Driver Behavior via Acceleration :
00-means turn and brake;
01-means accelerate.
acc_x
Acceleration at X axis
g
acc_y
Acceleration at Y axis
g
acc_z
Acceleration at Z axis
g
accident_acc
Accident alarm code
ignition_status
Ignition status:
0-means ACC OFF;
1-means ACC ON.
bluetooth_mac
Bluetooth Mac Address
rs232_data
RS 232 data from device
msg
Text message
tire_sens_id
RS232 Data From device:
Tire Pressure Sensor ID
tire_bat_v
Tire Presure Sensor Battery Voltage
V
tire_press
Tire Pressure
kPa
tire_air_temp
Tire Air Temperature
C
tire_status
Tire Pressure Data Status:
0 - normal tire pressure data;
128 - tire pressure leak alarm.
fing_cmd
Fignerprint information : command
fing_res
Fignerprint information : responce
fing_user_id
Fignerprint information : user id
fing_role
Fignerprint information : role
fingerprint
Fignerprint information : fingerprint
rfid
RFID
fuel_lvl
Fuel level
data_type
Fuel level data type:
0 - means normal data;
1 - means fuel filling;
2- means fuel leak.
rem_height
Remaining Height in Tank
mm
temp
Tank Temperature
C
level_height
Full Level Height
mm
fuel_type
Fuel type:
0 - diesel;
1 - petrol;
3 - water.
ble_code
BLE Data From device:
BLE Data Code
ble_#_battery
# - tire sensor ID
V
tire_#_press
# - tire sensor ID
kPa
tire_#_air_temp
# - tire sensor ID
C
tire_#_press_status
BLE Data From device:Tire Pressure Data Status
# - tire sensor ID
1 - tire pressure leak alarm;
2 - tire air refilling alarm;
3 - wheel rolling alarm
ble_tag_id
BLE Tag ID
ble_#_sos_type
BLE SOS Data Type
# - BLE Tag ID
0 - SOS alarm;
1 - low battery alarm.
ble_#_gnss_status
BLE Data and GNSS Status
# - BLE Tag ID
ble_#_driver_ident_type
BLE Driver Identification Data Type
# - BLE Tag ID
0 - Driver ID data;
ble_gnss_#_status
# - BLE Tag ID
network_operator
Network Operators Name
access_name
Access Technology Name
band_name
Band Name
imsi
SIM Card IMSI
iccid
ICCID
Grow your business with us
