Meitrack MDVR MD500S
Manufacturer: Meitrack
Number of units
40
Online
109
Total
Features Meitrack MDVR MD500S:
  • 3G
  • 4G/LTE
  • ADAS
  • Blackbox
  • BLE enabled
  • DMS
  • GLONASS support
  • Sending data to multiple servers
  • Built-in odometer
  • Passenger counter
  • Voice calls
Supported in Wialon:
  • Accelerometer
  • ADC sensors
  • Camera connection
  • CAN-bus support
  • Event video
  • Remote management via GPRS
  • Driver identification
  • Digital sensors(RS232/RS485)
  • Live stream
  • Manual video saving
  • Playback
  • Alarm button
  • Communication via TCP
  • Communication via UDP
The following data should also be added to Meitrack MDVR MD500S unit properties section of Wialon GPS tracking software :
Device type: Meitrack MDVR MD500S
Unique ID: imei
Specify the following parameters in configuration software or configuration Meitrack MDVR MD500S for use in Wialon Hosting :
Server port: 21792
109 units of Meitrack MDVR MD500S device type are connected to Wialon Data Center. This represents 0.17% of all Video monitoring connected.
cam_num Total number of cameras that this device supports
cam_status
Bitwise parameter of cameras connected status.
bit1 - 1 indicates Camera 1 is connected; 0 indicates Camera 1 is disconnected;
bit64 - indicates Camera 64 status
time_start
Start time
time_end
End time
alarm_flag8
Alert event code
Bytes 0–5: reserved
Bytes 6–7: Correspond to Meitrack's event codes, big-endian
av_type
Audio and video resource type
0: Audio and video
1: Audio
2: Video
3: Video, or audio and video
stream_type
Bitrate type
0: All streams
1: Major stream
2: Minor stream
cap_type
Memory type
0: All memories
1: Active memory
2: Standby memory
file_length
File size. Unit: byte, big-endian
video_uri
Video URI
video_type
Video type
ftp_upload_percent
Uploading progress percentage. Value range: 0–100.
ftp_filename
File name
RFID RFID code
event_code
Event Code
Event number Event description
1 SOS Pressed
2 Input 2 Active
3 Input 3 Active
4 Input 4 Active
5 Input 5 Active
6 Input 6 Active
7 Input 7 Active
8 Input 8 Active
9 Input 1 Inactive
10 Input 2 Inactive
11 Input 3 Inactive
12 Input 4 Inactive
13 Input 5 Inactive
14 Input 6 Inactive
15 Input 7 Inactive
16 Input 8 Inactive
18 Low External Battery
19 Speeding
20 Enter Geo-fence
21 Exit Geo-fence
22 External Battery On
23 External Battery Cut
24 GPS Signal Lost
25 GPS Signal Recovery
26 Enter Sleep
27 Exit Sleep
28 GPS Antenna Cut
29 Device Reboot
31 Heartbeat
32 Cornering
33 Track By Distance
34 Reply Current(Passive)
35 Track By Time Interval
36 Tow
37 RFID
41 Stop moving
42 Start moving
50 Temperature High
51 Temperature Low
52 Full Fuel
53 Low Fuel
54 Fuel Theft
70 Reject Incoming Call
71 Get Location by Call
72 Auto Answer Incoming Call
78 EEP2_MDVR_EVENT_IMPACT
82 Fuel Filling
83 Ult-Sensor Drop
87 18519
90 Sharp Turn to Left
91 Sharp Turn to Right
94 Output 1 Active
95 Output 2 Active
96 Output 3 Active
97 Output 4 Active
98 Output 5 Active
99 Output 1 Inactive
100 Output 2 Inactive
101 Output 3 Inactive
102 Output 4 Inactive
103 Output 5 Inactive
117 People Counter
129 Harsh Braking
130 Harsh acceleration
133 Idle Overtime
134 Idle Recovery(Recovery from Idle Overtime)
135 Fatigue Driving
136 Enough Rest after Fatigue Driving
138 Speed Recovery
139 Maintenance Notice
159 Out6 Active
160 Out7 Active
161 Out8 Active
162 Out6 Inactive
163 Out7 Inactive
164 Out8 Inactive
576 CH1 Video Loss
577 CH2 Video Loss
578 CH3 Video Loss
579 CH4 Video Loss
580 CH5 Video Loss
581 CH6 Video Loss
608 Storage Error
609 Full Storage
610 CH1 Video Recovery
611 CH2 Video Recovery
612 CH3 Video Recovery
613 CH4 Video Recovery
614 CH5 Video Recovery
615 CH6 Video Recovery
126ADAS/DMS event
gps_valid GPS status
gsm_signal GSM signal
hdop Horizontal Dilution of Precision
mileage Total accumulated mileage km
run_time Total accumulated runtime
battery battery charge %
adc5
Voltage of external power supply * 100
V
fuel_percent Percentage of remain fuel %
temp_N Temperature sensor N value °C
wln_accel_max Maximum acceleration value g
wln_brk_max Maximum deceleration value g
lls_N_temp
LLS fuel sensor N temperature
°C
lls_N_val
LLS fuel sensor value
lls_N_freq
LLS fuel sensor frequency
dr_f_status
Driver fatigue alert:
  • 01 - Mild fatigue
  • 02 - Moderate fatigue
  • 03 - Severe fatigue
  • 04 - Distraction alert
  • 05 - Absence alert
  • 06 - On Phone Call alert
  • 07 - Smoking alert
  • 08 - Yawning alert
mccN
Mobile country code for SIM card in slot N
mncN
Mobile network code for SIM card in slot N
lacN
Local area code for SIM card in slot N
cell_idN
Cellular station identification for SIM card in slot N
outputs_status
Output status
inputs_status
Bits 0–31 correspond to status of input ports 1–31
system_flag
The data is available only when the GPRS event code is 35.
Bit 0: Whether to modify the EEP2 parameter. When the parameter value is 1, the EEP2 parameter is modified.
Bit 1: Indicates the ACC status. When the parameter value is 1, the ACC is on.
Bit 2: Indicates the anti-theft status. When the parameter value is 1, the tracker is in the arming state.
Bit 3: Reserved.
Bit 4: Moving flag. When the parameter value is 1, the tracker is moving.
Bit 5: Whether to connect the external power
supply. When the parameter value is 1, the external power supply is connected.
Bit 6: Whether the tracker is charging. When the parameter value is 1, the tracker is charging.
Bit 7: Whether to enable the sleep mode. When the parameter value is 1, the sleep mode is enabled.
Bit 8: Whether to connect the FMS. When the parameter value is 1, the FMS is connected.
Bit 9: Whether to enable the FMS function. When the parameter value is 1, the function is enabled.
netw_ver
The version of the network being connected, 0x01 by default
netw_type
The type of network being connected,
0: No Network,
1: Mobile Network,
2:WIFI (Reserved),
3: LAN (Reserved)
adc1-3
Analog input value * 100
V
adc4
Battery analog *100
V
Grow your business with us
