Meitrack MD511H
Meitrack MD511H
Manufacturer: Meitrack
Number of units
Online
Total
Features Meitrack MD511H:
  • 4G/LTE
  • Blackbox
  • GLONASS support
Supported in Wialon:
  • Live stream
  • Communication via TCP
The following data should also be added to Meitrack MD511H unit properties section of Wialon GPS tracking software :
Device type: Meitrack MD511H
Unique ID: imei
Specify the following parameters in configuration software or configuration Meitrack MD511H for use in Wialon Hosting :
Server port: 21792
5 units of Meitrack MD511H device type are connected to Wialon Data Center. This represents 0.01% of all Video monitoring connected.
cam_num Total number of cameras that this device supports
cam_status
Bitwise parameter of cameras connected status.
bit1 - 1 indicates Camera 1 is connected; 0 indicates Camera 1 is disconnected;
bit64 - indicates Camera 64 status
time_start
Start time
time_end
End time
alarm_flag8
Alert event code
Bytes 0–5: reserved
Bytes 6–7: Correspond to Meitrack's event codes, big-endian
av_type
Audio and video resource type
0: Audio and video
1: Audio
2: Video
3: Video, or audio and video
stream_type
Bitrate type
0: All streams
1: Major stream
2: Minor stream
cap_type
Memory type
0: All memories
1: Active memory
2: Standby memory
file_length
File size. Unit: byte, big-endian
video_uri
Video URI
video_type
Video type
ftp_upload_percent
Uploading progress percentage. Value range: 0–100.
ftp_filename
File name
RFID RFID code
code Event Code
valid GPS status
gsm GSM signal
hdop Horizontal Dilution of Precision
mileage Total accumulated mileage km
engine_hours Total accumulated runtime
battery battery charge V
pwr_ext Voltage of external power supply V
fuel_percent Percentage of remain fuel %
temp_N Temperature sensor N value °C
wln_accel_max Maximum acceleration value g
wln_brk_max Maximum deceleration value g
lls_N_temp
LLS fuel sensor N temperature
°C
lls_N_val
LLS fuel sensor value
lls_N_freq
LLS fuel sensor frequency
dr_f_status
Driver fatigue alert:
  • 01 - Mild fatigue
  • 02 - Moderate fatigue
  • 03 - Severe fatigue
  • 04 - Distraction alert
  • 05 - Absence alert
  • 06 - On Phone Call alert
  • 07 - Smoking alert
  • 08 - Yawning alert
Grow your business with us
