Meitrack MD600
Meitrack MD600
Manufacturer: Meitrack
Number of units
28
Online
51
Total
Features Meitrack MD600:
  • 3G
  • 4G/LTE
  • ADAS
  • Blackbox
  • BLE enabled
  • CMSv6 support
  • DMS
  • GLONASS support
  • Sending data to multiple servers
  • Built-in odometer
  • Voice calls
Supported in Wialon:
  • Accelerometer
  • ADC sensors
  • Camera connection
  • CAN-bus support
  • Event video
  • Remote management via GPRS
  • Driver identification
  • Digital sensors(RS232/RS485)
  • Live stream
  • Manual video saving
  • Playback
  • Alarm button
  • Communication via TCP
  • Communication via UDP
The following data should also be added to Meitrack MD600 unit properties section of Wialon GPS tracking software :
Device type: Meitrack MD600
Unique ID: imei
Specify the following parameters in configuration software or configuration Meitrack MD600 for use in Wialon Hosting :
Server port: 22637
51 units of Meitrack MD600 device type are connected to Wialon Data Center. This represents 0.08% of all Video monitoring connected.
cam_num Total number of cameras that this device supports
cam_status
Bitwise parameter of cameras connected status.
bit1 - 1 indicates Camera 1 is connected; 0 indicates Camera 1 is disconnected;
bit64 - indicates Camera 64 status
time_start
Start time
time_end
End time
alarm_flag8
Alert event code
Bytes 0–5: reserved
Bytes 6–7: Correspond to Meitrack's event codes, big-endian
av_type
Audio and video resource type
0: Audio and video
1: Audio
2: Video
3: Video, or audio and video
stream_type
Bitrate type
0: All streams
1: Major stream
2: Minor stream
cap_type
Memory type
0: All memories
1: Active memory
2: Standby memory
file_length
File size. Unit: byte, big-endian
video_uri
Video URI
video_type
Video type
ftp_upload_percent
Uploading progress percentage. Value range: 0–100.
ftp_filename
File name
RFID RFID code
event_code
Event Code
Event numberEvent description
1SOS Pressed
2Input 2 Active
3Input 3 Active
4Input 4 Active
5Input 5 Active
6Input 6 Active
7Input 7 Active
8Input 8 Active
9Input 1 Inactive
10Input 2 Inactive
11Input 3 Inactive
12Input 4 Inactive
13Input 5 Inactive
14Input 6 Inactive
15Input 7 Inactive
16Input 8 Inactive
18Low External Battery
19Speeding
20Enter Geo-fence
21Exit Geo-fence
22External Battery On
23External Battery Cut
24GPS Signal Lost
25GPS Signal Recovery
26Enter Sleep
27Exit Sleep
28GPS Antenna Cut
29Device Reboot
31Heartbeat
32Cornering
33Track By Distance
34Reply Current(Passive)
35Track By Time Interval
36Tow
37RFID
41Stop moving
42Start moving
50Temperature High
51Temperature Low
52Full Fuel
53Low Fuel
54Fuel Theft
70Reject Incoming Call
71Get Location by Call
72Auto Answer Incoming Call
78EEP2_MDVR_EVENT_IMPACT
82Fuel Filling
83Ult-Sensor Drop
8718519
90Sharp Turn to Left
91Sharp Turn to Right
94Output 1 Active
95Output 2 Active
96Output 3 Active
97Output 4 Active
98Output 5 Active
99Output 1 Inactive
100Output 2 Inactive
101Output 3 Inactive
102Output 4 Inactive
103Output 5 Inactive
117People Counter
129Harsh Braking
130Harsh acceleration
133Idle Overtime
134Idle Recovery(Recovery from Idle Overtime)
135Fatigue Driving
136Enough Rest after Fatigue Driving
138Speed Recovery
139Maintenance Notice
159Out6 Active
160Out7 Active
161Out8 Active
162Out6 Inactive
163Out7 Inactive
164Out8 Inactive
576CH1 Video Loss
577CH2 Video Loss
578CH3 Video Loss
579CH4 Video Loss
580CH5 Video Loss
581CH6 Video Loss
608Storage Error
609Full Storage
610CH1 Video Recovery
611CH2 Video Recovery
612CH3 Video Recovery
613CH4 Video Recovery
614CH5 Video Recovery
615CH6 Video Recovery
648Forward-CW
650Pedestrian-CW
651Left-LDW
652Right-LDW
653HMW(Distance)
655DMS_CALL
656DMS_SMOKING
657DMS_TIRED
658DMS_YAWN
659DMS_DISTRACT
660DMS_LOSE
661DMS_COVERED
662DMS_IR_BLOCK
663DMS_SEATBELT
669BSD_FRONT
670BSD_BEHIND
671BSD_LEFT
672BSD_RIGHT
valid GPS status
gsm GSM signal
hdop Horizontal Dilution of Precision
mileage Total accumulated mileage km
engine_hours Total accumulated runtime
battery battery charge V
pwr_ext Voltage of external power supply V
fuel_percent Percentage of remain fuel %
temp_N Temperature sensor N value °C
wln_accel_max Maximum acceleration value g
wln_brk_max Maximum deceleration value g
lls_N_temp
LLS fuel sensor N temperature
°C
lls_N_val
LLS fuel sensor value
lls_N_freq
LLS fuel sensor frequency
dr_f_status
Driver fatigue alert:
  • 01 - Mild fatigue
  • 02 - Moderate fatigue
  • 03 - Severe fatigue
  • 04 - Distraction alert
  • 05 - Absence alert
  • 06 - On Phone Call alert
  • 07 - Smoking alert
  • 08 - Yawning alert
Grow your business with us
