Queclink GV355CEU
Number of units
1870
Online
2943
Total
Features Queclink GV355CEU:
  • 4G/LTE
  • Blackbox
  • BLE enabled
  • Built-in odometer
Supported in Wialon:
  • Accelerometer
  • ADC sensors
  • Camera connection
  • CAN-bus support
  • Remote management via GPRS
  • Driver identification
  • Remote management via SMS
  • Tachograph file download
  • Communication via TCP
  • Communication via UDP
The following data should also be added to Queclink GV355CEU unit properties section of Wialon GPS tracking software :
Device type: Queclink GV355CEU
Unique ID: imei
Specify the following parameters in configuration software or configuration Queclink GV355CEU for use in Wialon Hosting :
Server port: 22546
2943 units of Queclink GV355CEU device type are connected to Wialon Data Center. This represents 0.13% of all AVL Hardware connected.
dev_type
Queclink device type
*HEX mode only
proto_ver
Queclink protocol version
*HEX mode only
fw_ver
Firmware version
*HEX mode only
battery
Battery level, 0-100
pwr_ext
External power source voltage
adc_mode
Analog Input Mode
adc1
Analog Input 1 voltage
din_status
Digital Input Mode
Ignition Detection 0x01
Digital Input1 0x02
Digital Input2 0x04
Digital Input3 0x08
dout_status
Digital Output Mode
Digital Output1 0x01
Digital Output2 0x02
Digital Output3 0x04
motion_status
curr_mileage
Current Trip Mileage
*HEX mode only
total_mileage
Total Mileage
*HEX mode only
curr_hourmetercount
Current Trip Hour Meter Count (accumulative ignition time)
*HEX mode only
total_hourmetercount
Total Hour Meter Count (accumulative ignition time)
*HEX mode only
csq_ber
CSQ BER,0-7/99
adcf fuel level in percent
lat_#
onewire#_temp
1-Wire temperature #, where # - number
can_total_brakes The total number of braking processes initiated by brake pedal
ign_off_duration Duration since last time the ignition is off
adc# Sensor Type
can_total_effective_eng_speed_time
Total time when the vehicle engine speed is effective
geo_area_mask_group_1
The bitwise mask for trigger condition composition of the corresponding GEO ID. Each bit, from bit 0 to bit 19, represents the logical state of the corresponding GEO ID to trigger the entering or exiting event. 1 means “The event of the GEO ID set is triggered”, and 0 means “The event of the GEO ID set is not triggered”.
bt#_index Index of the Bluetooth device
can_total_dist_imp
Vehicle total distance measured in Impulses (if distance from dashboard is not available)
I
head Report head
can_rapid_brakings Number of total rapid brakings since installation
ext_gps_ant External gps antena
bt#_type
<Accessory Type>: The type of the Bluetooth accessory which is defined in the <Index>. The following is supported now:
  • 0: No Bluetooth accessory.
  • 1: Escort Bluetooth Accessory.
  • 2: Beacon temperature sensor
  • 6: Beacon Multi-Functional Sensor.
  • 7: Technoton accessory
adc3 Analog input 3
can_fuel_consumpt Fuel consumption
can_ign_key Ignition key, 0-no, 1-yes
can_total_accel_kickdown_time Total time when accelerator pedal is pressed over 90%
eio100_inputs The status of EIO100 inputs. For each bit, 0 means “Disable status”, and 1 means “Enable status”.
can_fuel_level_p The level of fuel in vehicle tank
onewire#_id 1-Wire ID #, where # - number
bt#_output
can_tacho_drv2_name The name of driver 2 from the tachograph
digit_fuel_sensor_data
<Digital Fuel Sensor Data>: The raw data read from the digital fuel sensor. If Bit 0 of <ERI Mask> in AT+GTFRI is enabled, this field will be displayed; otherwise, this field will not be displayed.
can_tacho_motion_sign The vehicle motion signal in the tachograph. 0: Motion is not detected 1: Motion is detected.
can_speed CAN speed value
onewire#_data 1-Wire data #, where # - number
onewire#_type 1-Wire type #, where # - number
pwr_int Internal Battery voltage
can_tacho_ovspd
Vehicle overspeed signal from the tachograph.
0: Overspeed is not detected.
1: Overspeed is detected.
can_all_starts
Total number of engine starts
can_fuel_level_l The level of fuel in vehicle tank
can_fuel_consumpt_unit Indicates the unit. The unit L/100km is represented as FE, and the unit L/H is represented as FF
can_eng_cool_temp Engine coolant temperature
mnc Mobile network code
serial_num Tracker serial number
can_range The number of kilometers to drive on remaining fuel
fuel_sensor#_type
The sensor type for the currently set table.
0: EPSILON ES2 or ES4
1: LLS 20160
2: DUT-E
3: QFS100
4: UFSxxx
5: Reserved
6: DUT-E SUM
20: ADC1
21: Reserved
rf#_type
ign_dur
Duration of Ignition
Duration of ignition ON (Report GTIGF)
Duration of ignition OFF (Report GTIGN)
can_handbrake_applies
Count events when handbrake is pulled-up while driving (speed is greater than 5 km/h)
can_ad_blue_lvl The level of Ad-Blue
can_tacho_drv2_card_number The card number of driver 2 from the tachograph
mcc Mobile Country Code
can_total_cruise_cntrl_time Weight of vehicle’s second axle
can_axle_weight_2 Weight of vehicle’s second axle
adc2 ADC2 input current value
can_ain1 The value of analog input
bt#_mask
If the device is connected with the Bluetooth accessory, and the
Bit 8 (for <Bluetooth Accessory Data>) of <ERI Mask> is set to 1, the device will report
+RESP:GTERI instead of +RESP:GTFRI. This mask is used to configure the accessory data fields to be reported in the +RESP:GTERI and +RESP:GTBAR messages.
  • Bit 0: <Accessory Name>
  • Bit 1: <Accessory MAC>
  • Bit 2: <Accessory Status>
  • Bit 3: <Accessory Battery Level>
  • Bit 4: <Accessory Temperature>
  • Bit 5: <Accessory Humidity>
Note
: When <Accessory Type> is set to 7, Bit 3-5 will be blocked. And when <Accessory Type> is set to 1 or 2, Bit 5 will be blocked.
fuel_sensor#_volume Fuel sensor volume
ges_radius The radius of the circular Geo-Fence region
can_total_eng_idle Total Engine Idle Time
can_eng_braking_factor Counts of braking with brake pedal or with engine
eio100_outputs 1-Wire Driver ID button
ibutton 1-Wire Driver ID button
can_cold_run_time
Total driving time with cold engine (engine coolant temperature below 70 C)
can_total_eng_hours Time of engine running since vehicle manufacture or device installation
can_axle_weight_3 Weight of vehicle’s third axle.
can_tacho_driv_direction
Vehicle driving direction from the tachograph.
0: Driving forward.
1: Driving backward.
can_rapid_accels Number of total rapid accelerations since installation
csq_rssi The network signal strength level
lon_
report Name of the report (+INF, +BNF, etc)
data_type
A hexadecimal parameter to indicate the time of the data (before crash or after crash) and crash direction (+X, -X, +Y, -Y, +Z, -Z or several of them).
lon_#
msg_type_EVT Type of +EVT or + BVT messages
bt#_dig_input_st
can_total_distance <Total Distance>: Vehicle total distance. The number is always increasing. The unit is hectometer (H)
can_total_driv_time Time of engine running (non-zero speed) since vehicle manufacture or device installation
can_total_fuel
The number of liters of fuel used since vehicle manufacture or device installation
liter
can_axle_weight_4
Weight of vehicle’s fourth axle.
can_detail_inf
It takes up two bytes. Each bit contains information of
one indicator.
Bit 0: FL – fuel low indicator (1 – indicator on, 0 – off).
Bit 1: DS – driver seatbelt indicator (1 – indicator on, 0 – indicator off).
Bit 2: AC – air conditioning (1 – on, 0 - off).
Bit 3: CC – cruise control (1 – active, 0 - disabled).
Bit 4: B – brake pedal (1 – pressed, 0 – released).
Bit 5: C – clutch pedal (1 – pressed, 0 – released).
Bit 6: H – handbrake (1 – pulled-up, 0 – released).
Bit 7: CL – central lock (1 – locked, 0 – unlocked).
Bit 8: R – reverse gear (1 – on, 0 – off).
Bit 9: RL – running lights (1 – on, 0 – off).
Bit 10: LB – low beams (1 – on, 0 – off).
Bit 11: HB – high beams (1 – on, 0 – off).
Bit 12: RFL – rear fog lights (1 – on, 0 – off).
Bit 13: FFL – front fog lights (1 – on, 0 – off).
Bit 14: D – doors (1 – any door opened, 0 – all doors closed).
Bit 15: T – trunk (1 – opened, 0 – closed).
can_lights
Each bit contains information of one particular light
Bit 0: Running Lights (1 – on, 0 – off).
Bit 1: Low Beam (1 – on, 0 – off).
Bit 2: High Beam (1 – on, 0 – off).
Bit 3: Front Fog Light (1 – on, 0 – off).
Bit 4: Rear Fog Light (1 – on, 0 – off).
Bit 5: Hazard Lights (1 – on, 0 – off).
Bit 6: Reserved.
Bit 7: Reserved.
fuel_sensor#_percent
Fuel sensor percentage
can_pedal_braking_factor
can_doors
Each bit contains information of one door:
Bit 1: Driver Door (1 – opened, 0 – closed).
Bit 2: Passenger Door (1 – opened, 0 – closed).
Bit 3: Rear Left Door (1 – opened, 0 – closed)
Bit 4: Rear Right Door (1 – opened, 0 – closed).
Bit 5: Trunk (1 – opened, 0 – closed).
Bit 6: Boot (1 – opened, 0 – closed).
Bit 7: Reserved.
Bit 8: Reserved.
can_starts_by_ign
Total number of engine starts by ignition
can_vin Vehicle identification number
can_total_veh_ovspd
The total time when vehicle engine speed is greater than the limit defined in CAN100's configuration
fuel_sensor#_dfs_data
bt#_an_input
speed_#
can_ad_blue_p
Ad-Blue level P-type
can_axle_weight_1
Weight of vehicle’s first axle
can_total_idle_fuel Total Idle Fuel Used
can_total_eng_ovspd The total time when vehicle engine speed is greater than the limit defined in CAN100's configuration
bt#_temp
It indicates the temperature measured by Bluetooth accessory.
bt#_mac
The MAC address of the Bluetooth accessory
can_cold_stats
Number of cold engine starts
fuel_sensor#_temp
can_acc_pedal_press Accelerator pedal pressure
can_exp_info
Detailed Information/Indicators:
Bit 1: W – webasto (1 – on, 0 – off or not available).
Bit 2: BFL – brake fluid low indicator (1 – on, 0 – off or not available).
Bit 3: CLL – coolant level low indicator (1 – on, 0 – off or not available).
Bit 4: BAT – battery indicator (1 – on, 0 – off or not available).
Bit 5: BF – brake system failure indicator (1 – on, 0 – off or not available).
Bit 6: OP – oil pressure indicator (1 – on, 0 – off or not available).
Bit 7: EH – engine hot indicator (1 – on, 0 – off or not available).
Bit 8: ABS – ABS failure indicator (1 – on, 0 – off or not available).
Bit 9: R – reverse.
Bit 10: CHK – check engine indicator (1 – on, 0 – off or not available).
Bit 11: AIR – airbags indicator (1 – on, 0 – off or not available).
Bit 12: SC – service call indicator (1 – on, 0 – off or not available).
Bit 13: OLL – oil level low indicator.
can_reg_number The vehicle registration number
can_total_accel_kickdowns Total time when accelerator pedal is pressed over 90%
can_tacho_drv1_card_number The card number of driver 1 from the tachograph
can_tacho_drv1_name
The name of driver 1 from the tachograph
can_dtc_num
DTC (Diagnostic Trouble Code) codes are used to diagnose malfunctions in a vehicle or heavy equipment
can_tacho_inf
Two bytes. The high byte describes driver 2, and the low byte describes driver 1.
can_eng_rpm Engine speed (from CAN)
can_ad_blue_l
AdBlue Level L type
alm_maskN
Alarm Mask 1-3 from the +RESP:GTCLT message
integer
cell_id
Cell Identifier
clt
+RESP:GTCLT message Identifier
gps_acc
A numeral to indicate the GNSS fix status and HDOP of the GNSS position.
0 means the current GNSS fix fails and the last known GNSS position is used. A non-zero.
value (1 - 50) means the current GNSS fix is successful and represents the HDOP of the current GNSS position.
group_id
The ID of the CANBUS alarm group. A total of 20 groups are supported.
lac
Location Area Code
msg_type_name
Message Type Name (FRI, ERI etc.)
report_head
Report header (GTFRI, GTERI)
btN_raw_data_dec
The decimal value for the Bluetooth accessory raw data. N is the Bluetooth accessory number in a queue.
tire_bat_volt_N
Tire Sensor Battery voltage
N is the Sensor ID
V
tire_press_N
Tire Pressure
N is the Sensor ID
Bar
tire_temp_N
Tire Temperature
N is the Sensor ID
C
tire_status_N
Tire Sensor Status
N is the Sensor ID
Bit 7: Sensor battery voltage status. 0 means normal. 1 means low battery voltage.
Bit 6: When no data is received from the sensor for a long time (60 minutes), this bit is set to 1.
Bit 5: 1 means automatic positioning is on. 0 means off.
Bit 4: 1 means high air pressure.
Bit 3: 1 means low air pressure.
Bit 2: 1 means high temperature. 0 means normal.
Bit 1-0: 00: Normal state. 01: Emergency air leakage. 10: Slow air leakage. 11: Gas filling.
tire_position_N
Tire Position
N is the Sensor ID
Grow your business with us
