Queclink CV5000
Number of units
Online
34
Total
Features Queclink CV5000:
  • 4G/LTE
  • ADAS
  • Blackbox
  • BLE enabled
  • DMS
Supported in Wialon:
  • Accelerometer
  • Event video
  • Remote management via GPRS
  • Live stream
  • Manual video saving
  • Playback
  • Remote management via SMS
  • Communication via TCP
The following data should also be added to Queclink CV5000 unit properties section of Wialon GPS tracking software :
Device type: Queclink CV5000
Unique ID: imei
Specify the following parameters in configuration software or configuration Queclink CV5000 for use in Wialon Hosting :
Server port: 22889
34 units of Queclink CV5000 device type are connected to Wialon Data Center. This represents 0.05% of all Video monitoring connected.
adc1
Analog Input 1 voltage
pwr_ext
External power source voltage
proto_ver
Queclink protocol version
*HEX mode only
motion_status
17 (0x11) Ignition off Rest: The vehicle is ignition off and motionless.
18 (0x12) Ignition off Motion: The vehicle had been moving before this action was regarded as car-towing event after ignition off.
33 (0x21) Ignition On Rest: The vehicle is ignition on and motionless.
34 (0x22) Ignition On Motion: The device is ignition on and moving.
curr_hourmetercount
Current Trip Hour Meter Count (accumulative ignition time)
*HEX mode only
din_status
Digital Input (bit mask)
bt_bat_level The voltage of Bluetooth accessory
fw_ver
Firmware version
*HEX mode only
dev_type
Queclink device type
*HEX mode only
adc_mode
Analog Input Mode
bt_status
  • 0 - the accessory is not available
  • 1 - the accessory is available
battery
Battery level, 0-100
bt_temp Temperature data fo Bluetooth accessory
curr_mileage
Current Trip Mileage
*HEX mode only
dout_status
Digital Output (bit mask)
total_mileage
Total Mileage
*HEX mode only
event_id
Events of driver safety system (ADAS and DMS).
Reports in GTDSS packet with the following values:
  • 1 - Eye Close
  • 2 - Yawling
  • 3 - Distraction
  • 4 - Smoking
  • 5 - Phone Use
  • 6 - Drive abnormal
  • 7 - IR blocking
  • 8 - Seatbelt unfastened
  • 20 - Forward collision warning
  • 21 - Pedestrian collision warning
  • 22 - Headway monitoring warning
csq_ber
CSQ BER,0-7/99
total_hourmetercount
Total Hour Meter Count (accumulative ignition time)
*HEX mode only
pwr_s whether the external power supply is connected.
ledon
  • 1 - Cell LED anf GNSS LED turn on as configured
  • 2 - Both LEDs work 10 minutes after tge device is powered on and then will be off.
indx
  • The index of Bluetooth accessory defined in AT+GTBAS which triggers the +RESP:GTBAA message
  • 0xFF for WKF300
alarm_type
  • 0 - the voltage of the Bluetooth accessory is low
  • 1 - the temperature alarm: current temperature value is below
  • 2 - the temperature alarm: current temperature value is upper
  • 3 - the temperature alarm: current temperature value is within the range defined by <low temperature> and <high temperature>
  • 4 - Push button event on WKF300 is detected
csq_rssi the level of signal strength
bt_name Bluetooth accessory name
acbe_model
The model of the bluetooth accessory
id_reptype
  • The ID is unauthorized or the ID authorization (IDA) function is disabled;
  • The ID is authorized
acces_type
  • 0 - No bluetooth accessory
  • 1 - Reserved
  • 2 - Beacon temperature sensor
  • 3 - BLE beacon ID device
id The ID which is currently read
charging Wheter the backup battery is charging when the main power supply is connected
can_eng_torgue Engine Torgue
bt_mac Bluetooth accessory mac
pwr_int pwr int
upc_result upc result
jamming_cw jamming cw
temp_device_id temp device id
z_side z side
mcu_ver mcu ver
upd_retry upd retry
x_forward x forward
wave1_out_id wave1 out id
upd_code upd code
resp_report_mask resp report mask
geo_id geo id
fuel_sensor[i]_percent fuel sensor[i] percent
y_forward y forward
z_vert z vert
sat_[sv_id] sat [sv id]
jamming_gps jamming gps
ibutton ibutton
x_vert x vert
x_side x side
fuel_sensor[i]_type fuel sensor[i] type
hw_ver hw ver
gps_signal_status gps signal status
z_forward z forward
crash_counter crash counter
y_vert y vert
fuel_sensor[i]_id fuel sensor[i] id
geo_area_mask_group_2 geo area mask group 2
onewire[i]_type onewire[i] type
gps_level gps level
sms_cmd_count sms cmd count
rx_level[i] rx level[i]
sms_msg_count_white sms msg count white
roaming_state roaming state
cell_id[i] cell id[i]
url url
ign_dur ign dur
geo_area_mask_group_1 geo area mask group 1
fuel_sensor[i]_volume fuel sensor[i] volume
temp_alarm_id temp alarm id
udp_cmd_count udp cmd count
upc_cmd_id upc cmd id
onewire[i]_data onewire[i] data
onewire[i]_id onewire[i] id
udp_msg_count udp msg count
mnc[i] mnc[i]
ges_mode ges mode
geo_area_type geo area type
jamming_indicator jamming indicator
phone_number phone number
fri_discard_no_fix fri discard no fix
geo_mask_group geo mask group
gir_trigger gir trigger
idle_dt idle dt
time_zone time zone
iccid iccid
ges_enabled ges enabled
tcp_msg_count tcp msg count
ign_dt ign dt
jamming_status jamming status
ges_radius ges radius
y_side y side
local_ip local ip
ta[i] ta[i]
wave1_out_active wave1 out active
sms_msg_count sms msg count
ges_dt ges dt
ibutton_auth ibutton auth
bat_status bat status
temp_status temp status
igf_dt igf dt
daylight_saving daylight saving
tcp_cmd_count tcp cmd count
lac[i] lac[i]
sms_cmd_count_white sms cmd count white
temp_device_data temp device data
Grow your business with us
