Queclink GV300W
Number of units
4518
Online
11034
Total
The following data should also be added to Queclink GV300W unit properties section of Wialon GPS tracking software :
Device type: Queclink GV300W
Unique ID: imei
Specify the following parameters in configuration software or configuration Queclink GV300W for use in Wialon Hosting :
Server port: 21795
11034 units of Queclink GV300W device type are connected to Wialon Data Center. This represents 0.49% of all AVL Hardware connected.
mcc
Mobile country code
mnc
Mobile network code
lac
Location area code
cell_id
Cell ID
hour_meter_count
Hour Meter Count
h
mileage
The total mileage
km
report_id
Report ID has different meanings in different messages
report_type
Report type has different meanings in different messages
inputN
The current logical status of the input port number N:
0 - is disable status
1 - is enable status
is_gtdis
GTDIS report type
pwr_ext
The voltage of the external power supply
V
pwr_int
The voltage of the backup battery. The value of this field is only valid when the external power is not connected
V
battery The current volume of the backup battery %
backup_battery
Backup Battery Percentage
status
Device Status
lls
Digit Fuel Sensor Data
onewireN_id
It indicates the device ID read from the 1-wire device (N)
onewireN_type
It indicates the type of the 1-wire device (N)
1: Temperature sensor.
onewireN_data
It indicates the data read from the 1-wire devices (N)
onewireN_temp
Temperaute value from onewire temperature sensor (N)
C
fuel_sensorN_type
Fuel sensor (N) type
fuel_sensorN_percent
Fuel sensor (N) percentage
fuel_sensorN_volume
Fuel sensor (N) volume
can_data
Data got from CAN device
iccid
The ICCID of the SIM card
csq_rssi
The GSM signal strength level. The range is 0-31, 99 for unknown
csq_ber
The quality of the GSM signal. The range is 0-7, 99 for unknown
bat_status
Whether the external power supply is connected
0: Not connected
1: Connected
charging
Whether the backup battery is charging when the main power supply is connected.
0 - not charging
1 - charging
led_on
Indicate whether the LED’s are turned on
pwr_saving_mode
The mode of power saving function. If <Power Saving Mode> is set to 0, the fixed report will follow <IGF Report Interval> when the engine is off. If <Power Saving Mode> is set to 1, the fixed report, geo-fence (AT+GTGEO and AT+GTPEO) and speed alarm (AT+GTSPD) report functions are suspended when the device is at rest or the engine is off, but auto parking fence and manual parking fence will not be suspended. If <Power Saving k Mode> is set to 2, it is mostly like mode 1 and the difference is that the fixed report will not be suspended and the fix and send interval of it will be set to <IGF Report Interval> in n AT+GTFRI when the engine is off:
0: Disable the power saving function.
1: Mode 1 of the power saving function 2: Mode 2 of the power saving function
ext_gnss_antenna
The status of the external GNSS antenna.
0: The external GNSS antenna of the device is working.
1: The external GNSS antenna of the device is detected in open circuit state.
3: The external GNSS antenna of the device is in unknown state.
pin15_mode
The current working mode of pin 15
din_status
Digital Input: A bitwise to represent the logic status of the digital input. For each bit, 0 means “Disable status”, and 1 means “Enable status”. If EIO100 device is not connected or the mode of AT+GTURT is not for EIO100, the optional Bits will not be included.
dout_status
Digital Output: A bitwise to represent the logic status of the digital output. For each bit, 0 means “Disable status”, and 1 means “Enable status”. If EIO100 device is not connected or the mode of AT+GTURT is not for EIO100, the optional Bits will not be included.
time_zone
The time offset of the local time zone from the UTC time
min
daylight_saving
The current setting of the daylight saving function.
0: Daylight saving is disabled.
1: Daylight saving is enabled.
motion_status
The current motion status of the device:
16 - Tow: The device attached vehicle is ignition off and it is towed.
1A - Fake Tow: The device attached vehicle is ignition off and it might be towed.
11 - Ignition Off Rest: The device attached vehicle is ignition off and it is motionless.
12 - Ignition Off Motion: The device attached vehicle is ignition off and it is moving
before it is considered as being towed.
21 - Ignition On Rest: The device attached vehicle is ignition on and it is motionless.
22 - Ignition On Motion: The device attached vehicle is ignition on and it is moving.
41 - Sensor Rest: The device attached vehicle is motionless without ignition signal
detected.
42 - Sensor Motion: The device attached vehicle is moving without ignition signal
detected.
ext_gps_ant
External GPS antenna status:
0 - is working
1 - is detected in open circuit state
3 - is in unknown state
incoming_phone_num
If <mon_type> is set to 1, <Stealth Phone Number> set by AT+GTMON will be filled in this field. If <mon_type> is set to 2, the number of incoming call which launches voice monitoring will be filled in this field.
mon_type
The type of voice monitoring phone call.
1: The current call is an outgoing call for voice monitoring.
2: The current call is an incoming call for voice monitoring.
stealth_microphone
It sets the volume of the microphone. 0 means “Disable microphone”.
stealth_speaker
It sets the volume of the speaker. 0 means “Disable speaker”.
dur_ign_off Duration since last time the ignition is turned off. If the duration is greater than 999999 seconds, it will be report as 999999 seconds. s
is_gtign
GTIGN report type
dur_ign_on
Duration since last time the ignition is on. If the duration i greater than 999999 seconds, it will be reported as 999999 seconds.
s
idle_dt
The time that the vehicle has been in idling status. If the duration is greater than 999999 seconds, it will be reported as 999999 seconds.
s
gps_signal_status
GPS signal status:
0 - lost GPS signal or no successful GPS fix
1 - GPS signal recovered and successful GPS fix
sats
The number of the visible satellites when fix succeeds. If fix fails, the parameter is empty.
fuel_input_id
The ID of the input to which the fuel sensor is connected.
fuel_level_last
The fuel level saved before last ignition off when the fuel loss alarm event occurs.
fuel_level_current
The current fuel level when the fuel loss alarm event occurs.
wave1_out_id The ID of the wave shape 1 output
wave1_out_active
The wave shape 1 output status
roaming_state
A numeral to indicate the roaming state of the device.
0: Home
1: Known roaming
2: Unknown roaming
3: Blocking report
camera_id
Camera ID
photo_time
Photo time
file_name
The name of the file transferred to FTP server. The suffix is “.jpg”.
fuel_hw_fault_code
The fault code of UFSxxx sensor.
Bit 0: Ultrasonic probe is not connected, or ultrasonic extension cable is broken.
Bit 1: Ultrasonic echo unstable. Check whether the ultrasonic probe is off.
Bit 2: System voltage error. Check whether the car voltage is low.
Bit 3: System abnormal reset.
Bit 4: The value of analog output is abnormal.
Bit 5: The current fuel level is in the blind zone.
Bit 6 – 15: Reserved.
upc_cmd_id
The command ID in the update configuration file. It is always 0 before the device starts to update device configuration. It is total number of the commands when the result code is 301. It indicates wrong format of command ID when the result code is 302.
upc_res
A numeral to indicate whether the configuration is updated successfully.
100: The update command is starting.
101: The update command is confirmed by the device.
102: The update command is refused by the device.
103: The update process is refused because the battery is low.
200: The device starts to download the package.
201: The device finishes downloading the package successfully.
202: The device fails to download the package.
300: The device starts to update the device configuration.
301: The device finishes updating the device configuration successfully. 302: The device fails to update the device configuration.
upc_url
The complete URL to download the configuration. It includes the file name.
pwr_on_reason
The reason for power on.
0: Normal power on
1: FOTA reboot
2: RTO reboot
3: Watchdog reboot
pwr_off_reason
The reason for power off.
0: RTO power off
1: Low battery voltage
2: RTO reboot
3: Watchdog reboot
jamming_net
The network mode.
1: GSM.
2: WCDMA
3: Both WCDMA and GSM.
jamming_status
The current jamming status of the device.
1: Quit the jamming state.
2: Enter the jamming state.
can_state
CANBUS Device State:
0 - Abnormal. It fails to receive data from the external CANBUS device.
1 - Normal. It is OK to receive data from the external CANBUS device.
can_vin Vehicle identification number
can_ignition_key
Ignition status:
0 - ignition off.
1 - ignition on.
2 - engine on.
can_total_dist_hect Vehicle total distance Hectometer (H)
can_total_dist_imp Vehicle total distance Impulse (I)
can_total_fuel_used Number of liters of fuel used since vehicle manufacture or device installation L
can_engine_rpm The revolutions per minute rpm
can_vehicle_speed The vehicle speed based on wheel km/h
can_eng_cool_temp Engine coolant temperature °C
can_fuel_consumpt
The fuel consumption. The consumption is calculated depending on values read from vehicle.
Note: The CAN100 device cannot get this value and the value is invalid.
can_fuel_level_l The level of fuel in vehicle tank L
can_fuel_level_p The level of fuel in vehicle tank %
can_range The number of hectometer to drive on remaining fuel Hectometer (H)
can_acc_pedal_press Accelerator pedal pressure %
can_total_eng_hours Time of engine running since vehicle manufacture or device installation h
can_total_driv_time Time of engine running (non-zero speed) since vehicle manufacture or device installation h
can_eng_idle_time Time of engine running during idling status (vehicle stopped) since vehicle manufacture or device installation h
can_idle_fuel_used Total idle fuel used. Number of liters of fuel used since vehicle manufacture or device installation L
can_axle_weight Vehicle axle weight kg
can_driverN_time_st
Driver N time related states:
0 - normal/no limits reached.
1 - 15 min before 41 h.
2 - 41 h reached.
3 - 15 min before 9 h.
4 - 9 h reached.
5 - 15 minute before 16 h (not having 8h rest during the last 24h).
6 - 16 h reached.
7 - other limit.
can_driverN_card
Driver N card state:
1 - card inserted,
0 - no card inserted
can_driverN_work_st
Driver N work state:
0 - normal / no limits reached.
1 - rest / sleeping.
2 - driver available / short break.
3 - drive / behind wheel.
can_indicators
Detailed Information/Indicators:
Bit 1: FL – fuel low indicator (1 – indicator on, 0 – off).
Bit 2: DS – driver seatbelt indicator (1 – indicator on, 0 – off).
Bit 3: AC – air conditioning (1 – on, 0 - off).
Bit 4: CC – cruise control (1 – active, 0 - disabled).
Bit 5: B – brake pedal (1 – pressed; 0 – released).
Bit 6: C – clutch pedal (1 – pressed; 0 – released).
Bit 7: H – handbrake (1 – pulled-up, 0 – released).
Bit 8: CL – central lock (1 – locked, 0 – unlocked).
Bit 9: R – reverse gear (1 – on, 0 – off).
Bit 10: RL – running lights (1 – on, 0 – off).
Bit 11: LB – low beams (1 – on, 0 – off).
Bit 12: HB – high beams (1 – on, 0 – off).
Bit 13: RFL – rear fog lights (1 – on, 0 – off).
Bit 14: FFL – front fog lights (1 – on, 0 – off).
Bit 15: D – doors (1 – any door opened, 0 – all doors closed).
Bit 16: T – trunk (1 – opened, 0 – closed).
can_light
Each bit contains information of particular light:
Bit 1: Running Lights (1 – on, 0 – off).
Bit 2: Low Beam (1 – on, 0 – off).
Bit 3: High Beam (1 – on, 0 – off).
Bit 4: Front Fog Light (1 – on, 0 – off).
Bit 5: Rear Fog Light (1 – on, 0 – off).
Bit 6: Hazard Lights (1 – on, 0 – off).
Bit 7: Reserved.
Bit 8: Reserved.
can_doors
Each bit contains information of one door:
Bit 1: Driver Door (1 – opened, 0 – closed).
Bit 2: Passenger Door (1 – opened, 0 – closed).
Bit 3: Rear Left Door (1 – opened, 0 – closed)
Bit 4: Rear Right Door (1 – opened, 0 – closed).
Bit 5: Trunk (1 – opened, 0 – closed).
Bit 6: Boot (1 – opened, 0 – closed).
Bit 7: Reserved.
Bit 8: Reserved.
report
Report type:
RESP
BUFF
msg_type
The ID of HEX report message
msg_type_name
Name of the packet
msg_type_RSP
Type of +RSP or + BSP messages
msg_type_EVT
Type of +EVT or + BVT messages
buffer
Existance of buffer:
0: report head "+RSP" or "+EVT"
1: report head "+BSP" or "+BVT"
head
Report head
dev_type
The type of device
proto_ver
Protocol version
fw_ver
Firmware version
adc_mode
Analog input mode
adc1
Analog Input1 Voltage
adc2
Analog Input2 Voltage
eio100_inputs
The status of EIO100 inputs. For each bit, 0 means “Disable status”, and 1 means “Enable status”.
eio100_outputs
The status of EIO100 outputs. For each bit, 0 means “Disable status”, and 1 means “Enable status”.
fuel_sensorN_id
Fuel sensor (N) ID
geo_id
The ID of Geo-Fence
phone_number
The phone number of the incoming call which triggers the report message
ibutton
iButton ID
ibutton_auth
iButton
ign_dur
Duration of Ignition:
Duration of ignition ON (Report GTIGF)
Duration of ignition OFF (Report GTIGN)
upd_code
UPD Code
upd_retry
UPD Retry
ges_enabled
The current Parking-Fence is active or inactive.
0: The current parking-fence is inactive.
1: The current parking-fence is active.
ges_mode
A numeral to indicate the trigger mode of the geofencing function.
0: Disable auto trigger mode.
21: Auto parking fence
22: Manual parking fence
ges_radius
The radius of the circular Geo-Fence region
m
ges_dt
The interval for GNSS checking position information against the Geo-Fence alarm.
temp_alarm_id The ID of the temperature alarm
temp_status
The status of the current temperature.
0 means “Outside the predefined temperature range”.
1 means “Inside the predefined temperature range”.
temp_device_id
The ID of the temperature sensor
temp_device_data
The current temperature the sensor detects
phl_mask
The <Attribute Mask> in the messages +RESP:GTPHL and +RESP:GTPHDThe <Attribute Mask> in the messages +RESP:GTPHL
fuel_sensor_type
Fuel sensor type
ufs_code
Information code.
100: Upgrade confirmed to be OK.
101: Mode error. UART does not work for UFSxxx. Stop upgrade.
102: The upgrade process is refused becauase of low power or an incorrect URL.
200: Start to download package.
201: Package download succeeds.
202: Package download fails.
300: Start upgrade.
301: Upgrade succeeds. The reserved parameter is used as follows. New Version 2 0
302: Upgrade fails.
ups_result
url
can_group_id
CAN group ID
can_alarm_mask_1
CAN Alarm mask 1
can_alarm_mask_2
CAN Alarm mask 2
can_alarm_mask_3
CAN Alarm mask 3
res_code
The result code of AT+GTAUS.
1: The working mode in AT+GTAUS mismatches with the port type.
port_type
Port type
0: Disabled
1: RS232
2: Reserved
3: 1-wire
port_id
Port ID of AU100
curr_mileage
The current mileage
km
curr_hourmetercount
The current hour meter count
h
total_mileage
The total mileage
km
total_hourmetercount
The total hour meter count
h
send_time
The local time to send the ACK message.
count_number
A self-increasing count number in each acknowledgment message and report message.
gps_acc
GPS accuracy
state
Device Status
Grow your business with us
