Suntech ST3300
Suntech ST3300
Manufacturer: ST SUNLAB (Suntech)
Number of units
2122
Online
5488
Total
Features Suntech ST3300:
  • Blackbox
The following data should also be added to Suntech ST3300 unit properties section of Wialon GPS tracking software :
Device type: Suntech ST3300
Unique ID: serial
Specify the following parameters in configuration software or configuration Suntech ST3300 for use in Wialon Hosting :
Server port: 21967
5488 units of Suntech ST3300 device type are connected to Wialon Data Center. This represents 0.24% of all AVL Hardware connected.
ver Software Version.
msg_type
  • 1 - report is real time;
  • 0 - report is storage.
cell_id Unique ID of Serving Cell
mcc Mobile Country Code
mnc Mobile Network Code.
lac Location Area Code.
rx_lvl Signal Strength.
fix
  • 1 - GPS is fixed;
  • 0 - GPS is not fixed.
mode
Mode the Device is in:
  • 0 - Parking;
  • 1 - Driving;
  • 2 - Idle;
  • 3 - Speeding;
  • 4 - Towing.
stt_rpt_type
Type of Report:
  • 0 - Response by CMD request ;
  • 1 - Time;
  • 2 - Distance;
  • 3 - Angle/Heading.
msg_num Message number.
alert_id Alert ID number.
alert_mod
Contains Modifier for certain Alert IDs
  • Number 1-8 of Temp sensor that triggered Alert ID 75, 76, or 77
  • Input that triggers Alert ID of Input High or Input Low
alert_data
Contains Data for certain Alert IDs:
  • RFID tag number;
  • Driver ID number;
  • Temperature Data.
s_asgn{n} Map of the custom assignable headers that can be included at the end of the standard report format. double
m_asgn{n} Map of the custom assignable headers that can be included at the end of the standard report format. double
l_asgn{n} Map of the custom assignable headers that can be included at the end of the standard report format. text
Grow your business with us
