Queclink CV100LG
Number of units
41
Online
157
Total
Features Queclink CV100LG:
  • 3G
  • 4G/LTE
  • Blackbox
Supported in Wialon:
  • Event video
  • Live stream
  • Manual video saving
  • Playback
The following data should also be added to Queclink CV100LG unit properties section of Wialon GPS tracking software :
Device type: Queclink CV100LG
Unique ID: imei
Specify the following parameters in configuration software or configuration Queclink CV100LG for use in Wialon Hosting :
Server port: 22197
157 units of Queclink CV100LG device type are connected to Wialon Data Center. This represents 0.25% of all Video monitoring connected.
dev_type
Queclink device type
*HEX mode only
proto_ver
Queclink protocol version
*HEX mode only
fw_ver
Firmware version
*HEX mode only
battery
Battery level, 0-100
pwr_ext
External power source voltage
adc_mode
Analog Input Mode
adc1
Analog Input 1 voltage
din_status
Digital Input (bit mask)
dout_status
Digital Output (bit mask)
motion_status
17 (0x11) Ignition off Rest: The vehicle is ignition off and motionless.
18 (0x12) Ignition off Motion: The vehicle had been moving before this action was regarded as car-towing event after ignition off.
33 (0x21) Ignition On Rest: The vehicle is ignition on and motionless.
34 (0x22) Ignition On Motion: The device is ignition on and moving.
phone_number
ign_dur
ibutton
ibutton_auth
geo_id
ges_enabled
ges_mode
ges_radius
ges_dt
geo_area_type
geo_mask_group
geo_area_mask_group_1
geo_area_mask_group_2
jamming_cw
jamming_gps
upc_cmd_id
upc_result
url
x_forward
y_forward
z_forward
x_side
y_side
z_side
x_vert
y_vert
z_vert
onewire[i]_id
onewire[i]_type
onewire[i]_data
fuel_sensor[i]_type
fuel_sensor[i]_id
fuel_sensor[i]_percent
fuel_sensor[i]_volume
pwr_int
jamming_status
crash_counter
upd_code
upd_retry
idle_dt
gps_signal_status
wave1_out_id
wave1_out_active
temp_alarm_id
temp_status
temp_device_id
temp_device_data
roaming_state
curr_mileage
Current Trip Mileage
*HEX mode only
total_mileage
Total Mileage
*HEX mode only
curr_hourmetercount
Current Trip Hour Meter Count (accumulative ignition time)
*HEX mode only
total_hourmetercount
Total Hour Meter Count (accumulative ignition time)
*HEX mode only
hw_ver
mcu_ver
fri_discard_no_fix
resp_report_mask
ign_dt
igf_dt
bat_status
iccid
csq_ber
CSQ BER,0-7/99
daylight_saving
time_zone
tcp_cmd_count
udp_cmd_count
sms_cmd_count_white
sms_cmd_count
tcp_msg_count
udp_msg_count
sms_msg_count_white
sms_msg_count
gir_trigger
mnc[i]
lac[i]
cell_id[i]
ta[i]
rx_level[i]
gps_level
jamming_indicator
sat_[sv_id]
local_ip
ledon
  • 1 - Cell LED anf GNSS LED turn on as configured
  • 2 - Both LEDs work 10 minutes after tge device is powered on and then will be off.
charging Wheter the backup battery is charging when the main power supply is connected
pwr_s whether the external power supply is connected.
csq_rssi the level of signal strength
id The ID which is currently read
id_reptype
  • The ID is unauthorized or the ID authorization (IDA) function is disabled;
  • The ID is authorized
indx
  • The index of Bluetooth accessory defined in AT+GTBAS which triggers the +RESP:GTBAA message
  • 0xFF for WKF300
acces_type
  • 0 - No bluetooth accessory
  • 1 - Reserved
  • 2 - Beacon temperature sensor
  • 3 - BLE beacon ID device
acbe_model
The model of the bluetooth accessory
alarm_type
  • 0 - the voltage of the Bluetooth accessory is low
  • 1 - the temperature alarm: current temperature value is below
  • 2 - the temperature alarm: current temperature value is upper
  • 3 - the temperature alarm: current temperature value is within the range defined by <low temperature> and <high temperature>
  • 4 - Push button event on WKF300 is detected
bt_name Bluetooth accessory name
bt_mac Bluetooth accessory mac
bt_status
  • 0 - the accessory is not available
  • 1 - the accessory is available
bt_bat_level The voltage of Bluetooth accessory
bt_temp Temperature data fo Bluetooth accessory
can_eng_torgue Engine Torgue
event_id
Events of driver safety system (ADAS and DMS).
Reports in GTDSS packet with the following values:
  • 1 - Eye Close
  • 2 - Yawling
  • 3 - Distraction
  • 4 - Smoking
  • 5 - Phone Use
  • 6 - Drive abnormal
  • 7 - IR blocking
  • 8 - Seatbelt unfastened
  • 20 - Forward collision warning
  • 21 - Pedestrian collision warning
  • 22 - Headway monitoring warning
Video functions work only if the Password field is completed in the unit properties. The default password is cv100.
How to use Queclink CV100LG in Wialon
Grow your business with us
