Suntech ST4500
Suntech ST4500
Manufacturer: ST SUNLAB (Suntech)
Number of units
249
Online
1419
Total
Features Suntech ST4500:
  • 4G/LTE
  • BLE enabled
  • Built-in odometer
Supported in Wialon:
  • ADC sensors
  • CAN-bus support
  • Remote management via GPRS
  • LBS
  • Remote management via SMS
  • Alarm button
  • Communication via TCP
The following data should also be added to Suntech ST4500 unit properties section of Wialon GPS tracking software :
Device type: Suntech ST4500
Unique ID: serial
Specify the following parameters in configuration software or configuration Suntech ST4500 for use in Wialon Hosting :
Server port: 21862
1419 units of Suntech ST4500 device type are connected to Wialon Data Center. This represents 1.69% of all OBD trackers connected.
gps_fix
  • 1 - GPS is fixed
  • 0 - GPS is not fixed
gps_interval This is interval to check GPS coordinates sec
gps_cnt
The GPS COUNT can be sent to Report at one time
gps_n Number of report gps parameters
robd_fw Device firmware
robd_protocol Comm protocol
robd_pin_v Dlc pin voltage
robd_vin Vin
robd_mil Mil
robd_m_supported Compression ignition monitor supported
robd_misfire
Misfire
robd_fuel Fuel
robd_cmpve Comprehensive
robd_ctlt Catalyst
robd_h_ctlt Heated catalyst
robd_evp_sys Evap system
robd_sec_air Secondary air
robd_iso_s_res Iso sae reserved
robd_o2sens O2sensor
robd_h_o2sens Heated o2sensor
robd_egr Egr
robd_n_r_cnt Not ready count
robd_dtc_cnt Dtc count
robd_erd Emission related dtcs
robd_pdc Pending dtc count
robd_pd Pending dtcs
robd_rpm Rpm
robd_pcm_id PcmId
Grow your business with us
