Hardware: devices integrated with Wialon in February 2021
Tmpxu H9of3
Remember, in the article on the Gurtam 2020 yearly results, we mentioned adding 132 device models that hadn’t been supported before? This is important information for the partner community as finding the hardware that would meet all the requirements is the vital aspect of the project’s success.
That’s why today we will explore the devices the use of which in Wialon became available in February 2021. Let’s start!
Squarell REMOTE
Manufacturer: Squarell Technology, the Netherlands
Squarell REMOTE
REMOTE is a one-box solution that combines a vehicle data interface with modem functionality. The compact design houses everything the telematics companies need to provide their customers with high-quality vehicle data and versatile connectivity. Additional accessories and peripherals, such as contactless vehicle data readers, a Bluetooth module, or Driver Awareness Panel can be connected using smart plug-and-play connectors.
Features:
  • 4G/LTE
  • 2G fallback
  • CAN interfaces: 4 (2 × read only and 2 × read/write) Auto baud, J1939, Layer 2
  • Inputs: J1708 inputs (2), K-Line input (1), ISO 11992 input (1), analogue inputs (2), SFD inputs (3)
Scope of application:
The device is available for order on the manufacturer’s website with worldwide delivery.
Gosafe GAT-1000
Manufacturer: Gosafe, China
Squarell REMOTE
GAT-1000 is the flagship trailer and asset tracker offering industry ruggedness to meet the harsh environment. The device has an embedded GEM (Gosafe Event Manager), giving you the opportunity to design the logic and features based on your needs.
Features:
  • 4G/LTE
  • BLE
  • COAP, TCP, UDP communication protocols support
  • IP rating: IP67
  • Battery: LI-ON 5000mAh
  • 3D accelerometer
  • Trailer and heavy equipment monitoring
Topflytech TLW2-12B
Manufacturer: Topflytech, China
Squarell REMOTE
Topflytech TLW2-12B can be powered when wired and towed by trucks and operate on the battery when trailers are not moving (power disconnected). The multiple inputs and outputs can be used for connecting accessories.
Features:
  • 2G+4G LTE-M (Cat M1) support
  • BLE
  • 3 digital inputs
  • 3 digital outputs
  • 3 configurable (digital and analog) inputs
  • Battery: rechargeable Li 9600 mAh
  • Temperature sensor
  • Trailer monitoring
Teltonika FMC125
Manufacturer: Teltonika, Lithuania
Squarell REMOTE
FMC125 is a small device with 4G (LTE Cat 1) network coverage including 3G (UMTS), 2G (GSM) fallback compatibility. The device is equipped with GNSS/Bluetooth and LTE modules, internal GNSS and LTE antennas. It is developed on the existing Teltonika FMB platform and can work with third-party RS232 or RS485 devices, digital fuel sensors (LLS), Garmin navigation devices, RFID readers, etc.
Features:
  • 3G
  • 4G/LTE
  • Blackbox
  • BLE
  • 2 SIM
  • CAN data reading
  • Temperature monitoring interface
  • Cargo monitoring
  • Video monitoring
  • Anti-theft solution
  • Driving quality control
  • Refrigerated trucks monitoring
The device is available for order on the manufacturer’s website in Latin America, Australia, Japan, EU, and MEA regions.
Concox JM-VG04
Manufacturer: Jimi IoT (Concox), China
Squarell REMOTE
Concox JM-VG04 a multifunctional tracker for vehicle monitoring. High ingress-protection capability prevents the intrusion of dust and water, ensuring its normal functioning in tough conditions. Designed with many inputs and outputs, it can connect to relays, panic buttons, fuel sensors, RFID readers, and other accessories.
Features:
  • Blackbox
  • GPS+LBS
  • 450mAh industrial-grade Li-Polymer battery
  • Vehicle monitoring
Trackimo Universal
Manufacturer: Trackimo, USA
Squarell REMOTE
An all-purpose smart 2G/3G GPS tracker with a variety of additional accessories released in 2014. The company’s bestseller.
Features:
  • 3G
  • 4G/LTE
  • Blackbox
  • SOS button
  • Waterproof
  • Vehicle and vessel fleets, outdoor use
  • Heavy-duty applications
Application example:
Trackimo Universal is used to monitor vessel fleets and delivery services.
Trackimo Travel
Squarell REMOTE
3G GPS tracker for travel and adventures with flight mode and a light sensor to keep the baggage safe. Released in 2016.
Features:
  • 3G
  • Blackbox
  • Pressure sensor
  • RFID tag
  • Personal tracking – employees, luggage monitoring
Trackimo Travel is used to monitor travelers and their luggage.
Trackimo Mini
Squarell REMOTE
Trackimo Mini is a 2G/Cat-M1 GPS tracker for children, pets, and valuable objects. Released in 2016.
Features:
  • Blackbox
  • Size and weight: 39 mm diameter and 20 g
  • Rechargeable battery Li-ion 300mAh
  • SOS button
  • Monitoring of children and pets
Trackimo Guardian
Squarell REMOTE
A smart compact 2G/3G GPS tracker for personal monitoring with exceptional design. Released in 2016.
Features:
  • Blackbox
  • Two programmable buttons
  • SOS button
  • Personal monitoring
Successfully used to monitor children, pets, elderly people, and security guards on duty.
Trackimo TrackiPro
Squarell REMOTE
3G asset tracker with up to 1 year of battery life. Released in 2020.
Features:
  • Battery: rechargeable Li-Ion 10 000mAh
  • IP rating IP67
  • Instant alerts
  • Accelerometer
  • Optional sensors (light, temperature)
  • Multiple geofence setup
You can order all the devices from today's review by contacting manufacturers directly or messaging us if you need their contact information. Find more details on the described devices on wialon.com in the Recently-integrated devices section.
Sign up for the Gurtam blog to stay informed on the latest products and company news. Also, please feel free to read the hardware FAQ and other articles on telematics devices.
If you are looking for a device suitable for your project, you’re welcome to address our hardware specialists team for help specifying your technical requirements. If you still can’t find the necessary device among the ones already supported by Wialon, you can request the device integration by writing at hw@gurtam.com.
5ec26066765c1
Olga Voytikhovich
