Queclink GL33CG
Number of units
23
Online
141
Total
Features Queclink GL33CG:
  • 2G
The following data should also be added to Queclink GL33CG unit properties section of Wialon GPS tracking software :
Device type: Queclink GL33CG
Unique ID: custom
Specify the following parameters in configuration software or configuration Queclink GL33CG for use in Wialon Hosting :
Server port: 22682
141 units of Queclink GL33CG device type are connected to Wialon Data Center. This represents 0.01% of all AVL Hardware connected.
msg_type_name
Report type of the message
buffer
Shows if the message was buffered
+BUFF header = buffer: 1
+RESP header = buffer: 0
mcc[NUM]
Mobile country code of the base station [NUM]
mnc[NUM]
Mobile Network code of the base station [NUM]
lac[NUM]
Location area code of the base station [NUM]
cell_id[NULL]
Cell tower ID of the base station [NUM]
rep_id
  • +RESP:GTGEO: indicates the ID of the Geo-Fence.
  • For other messages, it is always 0.
rep_type
rep_type has several meanings for the different packages
  • +RESP:GTNMR
    • 0 - The state of the device changes from motion to rest.
    • 1 - The state of the device changes from rest to motion.
  • +RESP:GTGEO
    • 0 - Exit the corresponding Geo-Fence.
    • 1 - Enter the corresponding Geo-Fence.
  • +RESP:GTDOG
    • 1 - Reboot device message for time based working mode.
    • 2 - Reserved
    • 3 - Reserved
    • 4 - Reboot device message for network watchdog
    • 5 - Reboot device message for EGPRS/LTE watchdog
    • 6 - Reboot device message for send failure watchdog
  • +RESP:GTFRI
    • Always 0 - This message is a common scheduled position report.
battery
The current volume of the battery in percentage.
rf_radio_status
Indicate status of the RF radio
  • 0 - RF433 is off
  • 1 - RF433 is on
rf_channel_freq
A number to indicate the transmit channel frequency of the RF433.
MHz
rat
Radio Access Technology.
  • 0 - NO SERVICE mode
  • 1 - EGPRS mode
  • 2 - Reserved
  • 3 - Reserved
  • 4 - LTE Cat1 mode
band
  • 0 means invalid band
  • 1-5/7-8/20/28 mean band number, and others mean GSM number.
motion_status
The current motion status of the device
  • 0x41 (Sensor Rest) - The device attached vehicle is motionless without ignition signal detected.
  • 0x42 (Sensor Motion) - The device attached vehicle is moving without ignition signal detected.
iccid
The ICCID of the SIM card.
rx_level
The signal strength level
  • For 2G/3G network
rx_level ⠀⠀⠀Signal Strength (dBm)
0 < -113
1 -111
2 - 30 -109 - -53
31 > -51
99 Unknown
  • For 4G Network
0 < -140
1 -140
2 - 96 -139 - -44
97 > -44
255 Unknown
rx_ber
The quality of the GSM signal. The range is 0-7, and 99 is for unknown strength of signal
network_type
The type of the mobile network the device is currently registered on.
  • 0 - Unregistered
  • 1 - EGPRS
  • 2 - Reserved
  • 3 - LTE
backup_battery_pwr
The voltage of the backup battery. The value of this field is valid only when the external power is not connected.
V
charge
Whether the backup battery is charging when the main power supply is connected.
  • 0 - Not charging.
  • 1 - Charging.
led_state
A numeral to indicate the working status of all LED lights.
  • 1 - All LEDs turn on as configured.
  • 2 - All LEDs work 5 minutes after powering on and then will be off. And all LEDs will work 5 minutes again after the power key is pressed shorter than 2 seconds.
last_fix_tm
The UTC time of the latest successful GNSS fix.
It has following format: HH:MM:SS DD/MM/YYYY
time_zone
Time zone offset from the UTC-0 Time
minutes
daylight_saving
The current setting of the daylight saving.
  • 0 - Daylight saving is disabled.
  • 1 - Daylight saving is enabled.
device_type
The type of the device
fw_ver
Firmware Version
hw_ver
Hardware Version
network_tm_check
A numeral to indicate whether to check GNSS UTC time with network time.
  • 0 - Only correct device time when the device can't get GNSS UTC time.
  • 1 - Always correct device time with network time.
total_packets
Total packets of GTALM packages
current_packet
Current packet of GTALM package
alm
The full configuration of the device from +RESP:GTALM
call_num
The phone number of the incoming call which triggers the report message.
report_composition_mask
Bitwise mask to configure the composition of a report message, especially the composition of GNSS information.
  • Bit 0 - for <Speed>
  • Bit 1 - for <Azimuth>
  • Bit 2 - for <Altitude>
  • Bit 3 - for Cell information, including <MCC>, <MNC>, <LAC>, <Cell ID>.
  • Bit 4 - for <Send Time>, the time when the report message is generated.
  • Bit 5 - for <Device Name>
For each bit, set it to 1 to enable the corresponding component in the report, and 0 to disable the corresponding component in the report. This mask is valid for all report messages. Bit3 is invalid for the +RESP:GTGSM message.
sv_[ID]
Satellite power of satellite [ID]. If there is no satellite, the field is filled with zero
fix_type
A string to indicate what kind of GNSS fix this cell information is for.
  • "RTL": This cell information is for RTL request.
  • "FRI": This cell information is for FRI request.
  • "GIR": This cell information is for the sub command "F" in the (AT+GTRTO) command.
upd_code | eud_code
+RESP:GTUPD
It indicates the download information.
  • 1x0 - The update command is confirmed by the device.
  • 1x1 - The update command is refused by the device.
  • 1x2 - The update process is cancelled by the backend server or refused because of an incorrect URL.
  • 1x3 - The update process is refused because the external power supply is not inserted.
  • 1x4 - Reserved.
  • 1x5 - The update process is refused because the upgraded unit is not working.
  • 2x0 - The device starts to download the package.
  • 2x1 - The device finishes downloading the package successfully.
  • 2x2 - The device fails to download the package.
  • 3x0 - The device starts to update the firmware.
  • 3x1 - The device finishes updating the firmware successfully.
  • 3x2 - The device fails to update the firmware.
  • 3x3 - The update process does not start because the battery is low.
  • 3x4 - Serial Number does not match, firmware upgrade fails.
+RESP:GTEUD
  • 1x0 - The device confirms this update command.
  • 1x1 - The device refuses this update command.
  • 1x2 - The backend server cancels this update process.
  • 1x3 - The device refuses this request because the battery is low.
  • 1x4 - The update process is refused because the upgraded unit is not working.
  • 2x1 - The device downloads the package successfully.
  • 3x1 - The device updates the firmware successfully.
  • 3x3 - The device cancels the firmware update because the battery is low.
download_times
The count number of the package download.
jamming_status
The current jamming status of the device.
  • 1 - Quit the jamming state.
  • 2 - Enter the jamming state.
battery_pwr
Battery Voltage
V
alm_type
The type of temperature alarm.
  • 1 - The current temperature is lower than the lower temperature limit defined by <Min Temperature>.
  • 2 - The current temperature is within the temperature threshold range specified by <Min Temperature> and <Max Temperature>.
  • 3 - The current temperature is higher than the higher temperature limit defined by <Max Temperature>.
temp
The current temperature of the device.
mode
The working mode of file transfer
  • 0 - Download file
protocol_type
The type of communication protocol used to obtain data from the backend server
  • 0 - HTTP
file_type
It defines the type of file to download from the server.
  • 0 - CA certificate
  • 1 - Client certificate
  • 2 - Client key
rtp_code
  • 100 - The update command is starting.
  • 101 - The update command is refused by the device.
  • 200 - The device starts to download the file.
  • 201 - The device finishes downloading the file successfully.
  • 202 - The device fails to download the file.
  • 301 - The device finishes updating the file successfully.
  • 302 - The device fails to update the file
ident_num
Identifier Number
A numeral to identify the firmware update request. It will be included in the +RESP:GTEUD message to indicate the request it is related to.
dev_type
Device type: Always 0x128 for Queclink GL33CG
gps_acc
GNSS Accuracy
A numeral to indicate the GNSS fix status and HDOP of the GNSS position.
  • 0 means the current GNSS fix fails and the last known GNSS position is used.
  • A non-zero value (1 - 50) means the current GNSS fix is successful and represents the HDOP of the current GNSS position.
Grow your business with us
